    let the F-Bodies roll jimmybling31's Avatar
    hixson tennessee
    94 camaro z28
    all needed to change to 3.73 gears
    I have an automatic transmission with a 2.73 gearing. what all is needed to change to a 3.73. I bought this off of texas speed
    http://www.texas-speed.com/shop/item...mid=54&catid=6
    I got it with 3.73 gears. is there anything else that I would need to get to change it over to 3.73. if so I will go ahead and order it tonight when I make an order on summit for something else.
    Fresno Ca
    LPM
    2002 Z28 Camaro
    I was wondering the same thing. Come on guys we need info.
    odessa,texas
    69 hugger orange
    98 z28
    just make sure your carrier is the right series, i believe it is 2 or 3 series
    those gears should be for a 3 series i believe
    texas speed should be able to help you out with a positive answer
    NC
    1998Z28
    You need a thick gear set for a series 2 carrier. You might better call Jon at TSP and make sure thats what you are getting because if not you will have to buy a series 3 carrier to make it work. Jegs sells a thick gear that is made to work with your series 2 carrier. It will also last longer because the gears are stronger.
    TSP 347 SB, TSP Stage 2.5 PRC LS6, TSP MS4, Performabuilt Stage 2 4L60E, Yank PT4000, 4.11s, Fast 90/90, FTRA Cold air intake+all the free mods, Dynatech Supermaxx Exaust System, DMH Cutouts, Hooker Catback/FTRA Tips. Tuned by RPM/Garner NC. 11.28@119
    hixson tennessee
    94 camaro z28
    I ordered a modified eaton lsd (3 series) to use. I read up on it before I bought it. it was 610 dollars and build to handle 475hp. from what I read it would be strong enough to stand up to the beating I will put on it.
    Member jcws6's Avatar
    Western Pennsylvania
    2002 Trans Am WS6
    That kit looks like pretty much everything you'll need.
    Do you plan on doing it yourself? If so, I'd recommend some loctite & RTV.
    hixson tennessee
    94 camaro z28
    Quote Originally Posted by jcws6 View Post
    I was going to if all I was doing was the gears, but I needed the differential so I am taking it somewhere.
    2002 Trans Am WS6
    I think you're making the right decision by taking it to a shop, but it would be the same amount of work whether you're just swapping gears or replacing a differential too. The ring bolts to the differential, so you'd have to take it out anyway. However, the job is a huge pain in the ass if you've never done it before, and a couple specialized tools are needed. Just make sure the place you take it to specializes in drivetrains/rear ends. It's pretty precise work, so there's something to be said about getting a quality job done.
    Out of curiosity, I looked up the Ratech install kit they include. Here's a part list: pinion shims, carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, cover gasket, and pinion, carrier bearings.
    hixson tennessee
    94 camaro z28
    wow that's alot of stuff it comes with. I was wondering too but have been too busy to check. I have never done it before, but if it weren't all new stuff going in it I wouldn't feel weird trying it.
  1. problems with change gears in high rpm´s
    By tomaski15 in forum General Help
    Last Post: 03-12-2012, 04:25 PM
  2. problems with change gears in higs rpm´s
    By tomaski15 in forum Manual Transmission
    Last Post: 03-12-2012, 10:20 AM
  3. Help: about to change my plastic gears for brass gears
    By edrvsqz1980 in forum General Help
    Last Post: 07-18-2009, 05:09 PM
  4. I want to change my gears, have two questions.
    By Cronex in forum Drivetrain
    Last Post: 03-31-2008, 08:08 AM
  5. Change gears, anything else to do at that time?
    By 666ws6 in forum Drivetrain
    Last Post: 03-19-2008, 06:18 AM
