Results 1 to 18 of 18
07-09-2009, 04:15 PM #1
about to change my plastic gears for brass gears
i will be changing my plastic gears for brass gears that rumbling noise is so embarassing. my question is, when i glue back the gear housing cover what kind of epoxy can i use. i did some research and it doesn't say what time to get. I bought some general purpose epoxy, i just want to make sure if it will hold, at the store i saw different kind. thanks for the help
07-09-2009, 08:35 PM #2
I bought some plastic epoxy made by loctite at walmart. its a little more expensive but theres NO WAY Ill ever get that housing back apart
07-09-2009, 09:38 PM #3
get the kit from rodney dickman. comes with everything you need. just did my pass side 2 days ago. when you do yours be sure you have 2 hours to let them sit and cure before you reinstall the headlight motor, and that you wont be needing to use your headlights for 24 hours as they need to cure 24 hours aswell before they operate.
http://www.rodneydickman.com/retail_new.html
comes with the epoxy you need.
i actually put the shaft back in the motor case backwards, and had to crack it back open and re-epoxy it. for this i used general epoxy from harbour freight tools, (less thana dollar)
07-10-2009, 03:24 AM #4Impounded
- Oct 2007
- Beaver Dam KY
07-10-2009, 05:19 AM #5
Make sure you put the gear assembly in correctly before you glue it up. My buddy did his the other night and put it in backwards.
07-10-2009, 11:17 AM #6
The cheapest 2 part epoxy kit I could buy...
Regards,
Todd
#cajunhotrodder on instagram
07-10-2009, 04:41 PM #7
thanks guys for the advise im about to glue it now
07-11-2009, 12:45 PM #8
i finish changing out the gears wasnt as hard as i thought but had trouble at the end but got it done i went with the epoxy made by loctite. really good stuff, thanks everyone for the advise
07-14-2009, 03:24 PM #9
where do i buy these brass gears?
07-14-2009, 03:55 PM #10
I actually bought them from some guy off of ls1.com but i dont remember his name they usually cost around 80.00 for both
07-14-2009, 03:58 PM #11
but heres a link i was given a while back http://my.execpc.com/C4/4A/rodney1/firebird/
07-14-2009, 04:02 PM #12
07-15-2009, 08:23 PM #13
That woudl have been Brent Franker, & he includes epoxy.
I bought some brass gears about 4 yrs ago or so from him for my WS6.
Here's his site: http://www.bfranker.badz28.com/headlightfix/index.htm
I just bought some decals from him a week ago as I'm redoing my 93 TA.
He's got great prices with fast shipping as well.
Here's the link to his decal page: http://www.bfranker.badz28.com/vinyl/vinyl.htm
07-16-2009, 03:52 AM #14
FWIW I bought the plastic gears that come on the card, you know that HELP stuff in the parts store, mine works fine, but my car is not a daily driver...
07-16-2009, 06:04 AM #15King 0f n00bz
- Jan 2006
- Shepherd, Michigan
do you guys pop up your lights when your in motion or close them while in motion ???
not to mention only 180 degrees are used on the gear so a spin and you are all set on the gear..oh well just thought i would warn ya guys..those brass gears..while nice..will add ALOT of stress on the motor due to the increase in weight
07-16-2009, 06:11 AM #16Impounded
- Oct 2007
- Beaver Dam KY
07-16-2009, 06:49 AM #17
07-18-2009, 06:09 PM #18
I wish I would have thought of that about about four years ago.I had to replace both of mine so I bought some used ones(money being tight and all),guess what ,they only lasted about one summer.Bought new ones next spring work great ever since.Just never thought to slow down for that,or that they made parts to fix them. Live and learn I guess.
all needed to change to 3.73 gears
By jimmybling31 in forum DrivetrainReplies: 8Last Post: 05-02-2008, 02:20 PM -
Change gears, anything else to do at that time?
By 666ws6 in forum DrivetrainReplies: 6Last Post: 03-19-2008, 07:18 AM -
Brass headlight gears
By GSXING in forum Firebird / WS6Replies: 3Last Post: 12-01-2006, 08:28 AM -
BFranker Brass headlight gears
By Hurley711 in forum Parts For Sale / TradeReplies: 4Last Post: 08-17-2005, 01:14 PM
