Results 1 to 14 of 14
03-27-2008, 02:19 PM #1
I want to change my gears, have two questions.
I have an A4 Trans Am with 2.73's installed from the factory. (I bought it used w/ 22K.) I want to change the gears to 3.73's but was wondering. Instead of getting the 12 bolt Moser rear with them, I was thinking of just getting the 3.73's and installing them into the 10 for now but was wondering if I would have to change the carrier too. I know in the older GM's you had to. But you didn't with the Fords. Is it still the same? Also does the 10 hold up good with 3.73's in them? All thats done mod wise is cat-back Loud Mouth 2 D/D, and I am either getting headers before or after this.
03-27-2008, 02:23 PM #2ArtistFormerlyKnownAsMac
- Apr 2006
- Indianapolis, IN
All Black- 83, 87, 02 All WS6 T/As
Well.. for one.. you either have 273s or 323s.. but since its not a WS6 its prob 273.. anyway.. I did 373s in my 10 bolt for like 8 months or so before I stripped the spider gear and went with a 12 bolt. Dont have to change the carrier.. just make sure you get the gears for the carrier you have.. there are 2...
-Geno
1983 Black WS6 "WindCharger"
1987 Black WS6 "WS87"
Sold the other four f-bodies
03-27-2008, 02:33 PM #3
I do have 2.73's. Don't know why I put 2.42's. But how would I know which carrier I have though? Is there an RPO, or a cast number, or what?
03-27-2008, 02:35 PM #4ArtistFormerlyKnownAsMac
- Apr 2006
- Indianapolis, IN
I can't remember.. but I wanna say the lt1s had a 2 channel and ls1s have a 3 channel or something like that.. youd have to ask around.. this almost 2 years ago...
03-27-2008, 02:39 PM #5
Oh ok, well thanks for the info. I appreciate it.
03-27-2008, 02:40 PM #6ArtistFormerlyKnownAsMac
- Apr 2006
- Indianapolis, IN
Np.. good luck...
03-28-2008, 12:25 PM #7
I'm pretty sure you'll need a 2 series carrier since there 2.73's
03-29-2008, 12:44 PM #8Member
- Billings,MT
Sunset Orange Metalic- 2002 Firehawk
I maybe opening a can of worms here,but I thought the Trans Am option came with 3.23 as standard with the A4.I did not think the 2.73 was a option for a Trans Am.I know about the option codes,but something seems fishy.CRONEX if you have the last eight in the vin # I can see what the factory says.
03-29-2008, 01:02 PM #9
03-29-2008, 07:25 PM #10
Mghawk57, 2.73's from the factory is legit. I already knew this, and posted about it in another thread titled Gear Ratio. You can check the RPO codes on the drivers door, no need to check the VIN #. Also, as Silver Streak pointed out 2.73's are the standard for A4's, RPO code GU2. RPO for the performance option 3.23's being GU5.
03-29-2008, 07:45 PM #11
...forgot to add. If you check on Texas Speed's website under 98-02 F-Bodies both Motive and Ratech sell gears for a 7.5 GM 10 bolt rear with a 3-series carrier. If you check SLP's website too they also sell gears for a 7.5 GM 10 bolt rear with 3-series carrier under 98-02 F-Bodies. So it is a 3-series carrier, they also put them in S-10 trucks too.
03-30-2008, 03:04 AM #12We'll be back...
- THE SWAMP
If your original gears are 3.08 or less, you have the 2-series carrier. So, those A4s with a 2.73, you have the 2-series. For those A4s with a 3.23, you have the 3-series.
03-31-2008, 03:43 AM #13Member
- Billings,MT
I guess I'm still not making my point.I thought the Trans Am option was upgraded to 3.23 gears as part of the Trans Am package.Maybe you can delete this and get 2.73.But I sure don't know everything I guess.
03-31-2008, 08:08 AM #14
problems with change gears in high rpm´s
By tomaski15 in forum General HelpReplies: 1Last Post: 03-12-2012, 04:25 PM -
problems with change gears in higs rpm´s
By tomaski15 in forum Manual TransmissionReplies: 1Last Post: 03-12-2012, 10:20 AM -
Help: about to change my plastic gears for brass gears
By edrvsqz1980 in forum General HelpReplies: 17Last Post: 07-18-2009, 05:09 PM -
all needed to change to 3.73 gears
By jimmybling31 in forum DrivetrainReplies: 8Last Post: 05-02-2008, 01:20 PM -
Change gears, anything else to do at that time?
By 666ws6 in forum DrivetrainReplies: 6Last Post: 03-19-2008, 06:18 AM
