Page 1 of 3 123 LastLast
Results 1 to 20 of 54
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    want a wider tire for my wheel, what will work?
    don't get hung up on the tire width number. that number is derived from measuring from sidewall to sidewall. what you need to pay attention to is the tread width. tread width is what touches the ground. most go the route of getting wider section width tires ( 275 to 315 ) i'll show you how to get more on the ground without changing overall section width.
    example all are 275/40-17 all specs taken off of tire rack website. these were measured on a 17 x 9.5" wide wheel.
    dunlop sp sport 9000 TW = 9.9"
    goodyear eagle f1 gs-d3 TW = 9.4"
    yokohama avs sport TW = 10.1"
    yokohama avs es100 TW = 10.7"
    bridgestone potenza re950 TW = 9.5"
    firestone firehawk wide oval TW = 9.5"
    fusion zri TW = 9.5"
    sumitomo htrz TW = 10.2"
    sumitomo htrz II TW = 9.9"
    as you can see, the yokohama avs es100 has the widest in terms of tread width at 10.7" and goodyear eagle f1 gs-d3 with the least at 9.4". tread width is what counts.
    Aug 2000
    Indy
    This Is A Standard, 17 Inch 9.5 Rim ?
    04 C5 A4 Torch Red - sold
    2009 CTS4 Ice Black - sold
    2013 1500 Silverado Z71 - sold
    02 Z/28 M6 Onyx Black All Options - Sold
    2014 Caddy CTS4 - DD
    2016 Silverado 2500HD
    2020 Caddy XT6
    2020 2SS Vert
    orlando, fl
    2014 camaro 2ss/rs
    edited to reflect that. remember, a stock factory fbody 17" wheel is 9" wide.
    Junior Member z06this's Avatar
    May 2008
    Minnesota
    98 Camaro z28
    the fuzion zri and goodyear gsd3s are probably the best tires out of those though. tough decision picking between tread width and a better overall tire. i'd go with the better tire.
    Member chevyss1234's Avatar
    Feb 2007
    Clemson SC
    is the yokohoma es100 going to physically look wider than the f1 gs-d3?
    orlando, fl
    2014 camaro 2ss/rs
    should. it has more tread width.
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    You should throw the sidewall widths up there too.
    Fresno Ca
    LPM
    2002 Z28 Camaro
    A mrr23 I have a question…. Do you know whats the widest tire you can properly mount on a stock 16” and a stock 17”?
    The Red Reaper 98Z28importslayer's Avatar
    Feb 2008
    Spring hill, TN
    1998 Camaro Z28 T-Top A4
    i beleive 255s are the widest you can put on 16x8 rims ??? i got 245s on mine and the tires are just way to small for a ls1 camaro ...
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    I've been running 285s on my stock 17s for several years.
    Member maxpit's Avatar
    San Diego, CA
    pewter
    02' Z28
    My girlfriend has a 98 firebird, i believe they're 16in but i was unsure of the width. From this thread i take it that they r 8in wide. They r chrome 5 spoke wheels... can anyone reassure me what her rim size is?
    orlando, fl
    2014 camaro 2ss/rs
    yes, the 16s are 8" wide
    Member Speeddemon24_7's Avatar
    Lancaster, SC
    Artic White
    1998 Chevrolet Camaro Z28
    Where do you find the Total width at I know the biggest tire I can run safe is 285 on my 18 x 9 1/2" Y2K's im also looking for the widest look also this is so go info to look at.
    orlando, fl
    2014 camaro 2ss/rs
    i think you are wanting to know where to find the Tread Width. on tirerack.com, once you select the tire, look for the word Specs. then look in the Tread Width column.
    Wisconsin
    2001 Camaro SS M6
    I have personnally been able to get my 275/40/17 GS-D3's to hook on a 5K clutch dump on public roads with mods below. I have tried a couple of the other tires but would say GS-D3 is in the top 3 for sure. I have tried the sumitomo's and potenza's. I am going with 315 GS-D3 after my H/C
    ┌∩┐(◕_◕)┌∩┐
    wouldn't want to fight them!
    09 G8 GT
    On the stock SS wheels? They come w/ 275s right, and you can safely put 315's? Interesting....
    Wisconsin
    2001 Camaro SS M6
    Quote Originally Posted by ls1fan74 View Post
    Yup, 275's stock. 315 on a 9" wheel is potentially dangerous and really shouldn't be done. Some people do it, but under hard cornering, the tire can blow. Going with a bigger wheel after H/C
    Jan 2008
    Athens AL
    Navy Blue
    1998 Formula Firebird
    As far as the 315's i am on my second set of them on y 17x9's with no problems and a lot of rough driving. the first set was bfg drag radials which i had to get 1/4" spacers to stop the rubbing, and now i have sumitomo htr z i love them the bfg's were good when you get them really hot, but as far as unexpected cold launches i might as have had big wheel tires on the back. the sumis dont compare on the track but as far as daily drivers they are awesome. i have had no problems in he rain with them either. I have had Goodyear eagles, Firestone Firehawks, and Fuzion Zri (loudest tire i ever owned) and since my car is my daily driver and adverse weather and ride quality are my main concerns, the sumitomos are here to stay. they re significantly cheaper and a full set 275's fronts and 315's rear for under 400 absolutely cannot be beat in my mind.
    Jun 2009
    Ohio
    1998 Z-28
    Smile Wider Tire for my 98 Z
    I autocross and am considering a larger tire "275/50/16" to replace the stock 245/50/ 16's. Can anyone tell me if these tires will work without rubbing? And, if I need a spacer, how large of a spacer do I need ?
    Henryetta/Tulsa Oklahoma
    2016 Camaro SS - Summit
    2001 Trans Am WS6 - NBM
    Quote Originally Posted by Bakerman View Post
    It will be fine. You can usually put on as large as a 315/35/17 on an 11" wide wheel with little to no massaging needed on the wells, so the little tire you are planning to put on will fit fine...just make sure that wide of a 16 actually fits your wheel... you don't want to lose it in a tight turn.
  1. Need wider rear tire for 77 camaro
    By Street Fighter in forum General Help
    Last Post: 11-20-2015, 06:33 PM
  2. Want a wider tire for my C6 rims, I need some advice!
    By hall_5950 in forum Wheels and Tires
    Last Post: 09-21-2011, 12:34 PM
  3. will this wheel/tire setup work?
    By wvbrett in forum Wheels and Tires
    Last Post: 05-10-2011, 03:55 PM
  4. wider tire on stock WS6
    By tav8ws6 in forum Wheels and Tires
    Last Post: 02-28-2009, 11:01 AM
  5. Wheel widened or wider wheels?
    By maxgee in forum Wheels and Tires
    Last Post: 07-19-2008, 05:41 PM
