Results 1 to 2 of 2
11-18-2015, 02:53 PM #1Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
Need wider rear tire for 77 camaro
What is the widest rear tire I can put on the rear of my 77 Camaro without tubing it.I have p275-60-15 on 8" wide olds rally wheels on the rear. can I get a set of 10" wheels with less back spacing, which would place the tire closer to the outer fender which may allow me to go wider on the rear tires. I am runing BF Goodrich tires which I have found to be a little wider than a lot of tires. I am not ruling out tubing but there is no one here that does it.
11-20-2015, 06:33 PM #211 years of bangin gears
- Jan 2009
- North Jersey
I am picturing your car with a set of the OEM rally wheels GM used for the Corvette, Camaro, and Chevelle SS but in a staggered form. Try looking those up because I am tempted to say they are available in 10" width. I could be wrong. Check out Wheel Vintiques. They have 10" rally wheels.
want a wider tire for my wheel, what will work?
By mrr23 in forum Wheels and TiresReplies: 53Last Post: 06-23-2012, 02:24 PM -
Want a wider tire for my C6 rims, I need some advice!
By hall_5950 in forum Wheels and TiresReplies: 10Last Post: 09-21-2011, 12:34 PM -
Old school camaro need wider wheels.
By Street Fighter in forum Wheels and TiresReplies: 3Last Post: 01-01-2011, 11:00 AM -
wider tire on stock WS6
By tav8ws6 in forum Wheels and TiresReplies: 4Last Post: 02-28-2009, 11:01 AM -
Uneven tire wear on rear tire??
By renzo in forum Wheels and TiresReplies: 2Last Post: 11-20-2006, 04:30 PM
