Thread: wider tire on stock WS6
02-27-2009, 10:15 AM #1Member
- Nov 2006
- New Jersey
Sunset Orange Metallic-M6- 2002 Pontiac Trans Am WS6
Would there be any disadvantages of putting a 285/40ZR17 Goodyear Eagle GS-D3s on the stock WS6 rim? I know they will fit on the WS6's 9.5" rim. Would the taller side wall give worse handling?
02-27-2009, 03:38 PM #2
I wouldn't see any issues. They're not much taller than the stock size. Here are some specs for you. (source: http://www.miata.net/garage/tirecalc.html)
Stock tire: 275/40/17
Sidewall: 4.3
Radius: 12.8
Diameter: 25.7
Circumference: 80.6
Revs/mile: 786.0
New tire: 285/40/17
Sidewall: 4.5
Radius: 13.0
Diameter: 26.0
Circumference: 81.6
Revs/mile: 776.0
02-28-2009, 05:27 AM #3MOTOR CITY MARO'
- Nov 2005
- LIVONIA,MICHIGAN
PEWTER- 2000 CAMARO SS #3821
I think our stock GM factory rims are 17x9, not 9.5. Maybe someone else can confirm this.
02-28-2009, 07:28 AM #4Crazy Canuck !
- Jun 2002
- Montreal, CANADA
stock wheels are in fact 17x9, not 17x9.5
It's the inside of the rim that defines the width... not the outside measurement.
There is no benifit on getting 285 over 275... the 275 will be mounted slightly better than the 285 and it won't screw up the odometer/speedometer staying with 275s.
You'll get a slightly taller tire and more rotational inertia... and your speedo will be off by a bit over 1% (no biggie).
but they'll fit no problem.Eugenio_SS
02-28-2009, 11:01 AM #5Member
- Nov 2006
- New Jersey
Oh, ok. Ill just stick with the 275s. Thanks for all the help guys!
Need wider rear tire for 77 camaro
By Street Fighter in forum General HelpReplies: 1Last Post: 11-20-2015, 06:33 PM -
want a wider tire for my wheel, what will work?
By mrr23 in forum Wheels and TiresReplies: 53Last Post: 06-23-2012, 02:24 PM -
Want a wider tire for my C6 rims, I need some advice!
By hall_5950 in forum Wheels and TiresReplies: 10Last Post: 09-21-2011, 12:34 PM -
Stock wheels with wider tires?
By Kamauxx in forum Wheels and TiresReplies: 5Last Post: 10-24-2007, 05:50 PM -
keep stock 16"rear rims or go to 18" the wider ones?
By greatwhiteZ28 in forum Wheels and TiresReplies: 7Last Post: 02-27-2007, 01:59 PM
