Thread: AC Not Working
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Question AC Not Working
    Blower fan runs, compressor isn't engaging though.
    No blown fuses, but I'm not sure how to check the relay.
    Guess I should let it cool down & check for power at the plug going into the compressor.
    Is there anything in the dash that needs looked at?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    maybe the freon is low? low pressure switch is bad? compressor clutch bad?
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    The clutch doesn't engage.
    It spins freely when I spin it with my finger.
    Unplugged the wires at the compressor & fired the engine, turned the AC on inside & was reading 2 volts on my meter.
    Does that sound like a low pressure switch problem?
    Freon?? Would being low not make the compressor clutch kick in??
    Thanks for the reply.
    the cake is a lie twozs's Avatar
    hopewell jct, ny
    black 01 red 73
    01 z28 and 73 z28
    the low pressure switch senses when the freon is low and shuts the system down. the evap coil could freeze and potentially slug liquid freon back to the compressor and damage the valves or pistons or such. its a safety device. you can try to jump it and see if the compressor starts (not my advice) which could at least isolate your problem
  1. ac not working
    By gillahoon in forum General Help
    Last Post: 08-02-2009, 09:19 AM
  2. Working Now Need Help
    By camarostripes96 in forum External Engine
    Last Post: 10-03-2007, 06:16 AM
  3. Working out
    By riceslayer302 in forum Almost Anything Goes
    Last Post: 05-06-2007, 04:11 PM
  4. what to eat after working out?
    Last Post: 01-07-2007, 08:33 AM
