Thread: ac not working
    Drive it like its stolen gillahoon's Avatar
    Carbondale, Pa
    ac not working
    ok been having problem with my ac blowing fueses so the other day it blew a fues and when i replaced it and ac still didnt work. so then i replaced the ac relay and it still dont work. i dont hear the compresser kicking on to make cold air. any idea what can be goin on.
    HERE WE GO STEELERS!!! michaelinchains's Avatar
    `da nati
    `99 GTP/`98 formy(sold)
    could very well be the clutch on the a/c compressor
    Northern Virginia
    BLACK
    Might sound stupid, but make sure you didn't simply throw the AC belt. I didn't have any fuse problems, but mine stopped working awhile back, and it was because the belt had broken.
    `da nati
    my GTP was doing the same thing as his car,but my car wouldnt crank over.i replaced the compressor & a/c clutch w/ a junkyard one,flushed & filled the system & all is well
    Custom Painter/Tech Customta98's Avatar
    Plainwell, Mi
    Flame Red / Orange Custom
    Yeah it sounds like the clutch for the AC compressor burned up. I say just remove it and take your T-Tops off (if you have them) that worked for me lol.
    98 Trans Am Custom Paint, Ghost Skuls On Racing Stripe + Custom Front Lip, :MODs Tubular K-member, Tubular Upper and lower A-arms, Tubular Control Arms, 4:10's, Cam L-.567/.575 [email protected]/.218,1.85 Roller Rockers, P&P Heads, ARH Headers & HF Cats & Y-Pipe, SLP loudmouth catback, +'s
    Junior Member jmurphyws6's Avatar
    Jul 2009
    raleigh nc
    2002 trans am ws6
    a/c
    un plug the compressor and see if the fuse still blows,if not your problem is the a/c clutch
    Carbondale, Pa
    well when i turn on the ac now the fuse dont blow but on the same token the compresser dont kick on
    Carbondale, Pa
    ok found the problem i burnt up the connector and all the way up the wire. I dont know how far its burnt wire goes so here is my question.
    1 does any wire hook in to the 2 wires that go from the fuse to the ac compressor casue i really dont want to fish out all that wire.
    2 can i just get the wire from the fuse box too the ac compresser, cause as i got up from the ac compresser looked like 4 wire were all looped with a little restor.
    so i just want to bypass ever there and run new wire from the fuse box to the compressor
  1. AC Not Working
    By rbob93 in forum General Help
    Last Post: 04-27-2008, 11:14 AM
  2. Working Now Need Help
    By camarostripes96 in forum External Engine
    Last Post: 10-03-2007, 06:16 AM
  3. Working out
    By riceslayer302 in forum Almost Anything Goes
    Last Post: 05-06-2007, 04:11 PM
  4. what to eat after working out?
    Last Post: 01-07-2007, 08:33 AM
