Results 1 to 10 of 10
    Junior Member McCool318's Avatar
    Valdosta, GA
    1998, A4, T-TOP, Trans Am
    High Pitched Noise
    My car is making a high pitched noise well after start up. It makes the noise when it first starts up but then shuts off. 5-10 minutes down the street I hear it make the same high pitched noise and my lights dim down or almost shut off then it kicks off again a few seconds later. Anyone know what cause this? Any helped appreciated.
    Member SilverSteen25's Avatar
    Pittsburgh, PA / State College, PA
    2000 Trans Am WS6
    Sounds like ur alternator is going bad
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Air pump??
    Valdosta, GA
    I will try and get a sound clip of it today and post it up in the afternoon. Cause it makes the noise on start up for a few seconds and goes away. It has always made the noise as long as my mom owned the car. It used to only do it on cold start ups. I haven't driven the car for a long distance and then got and cut it off then started it up later and drive it again. I just use the TA to get back and fourth to work right now. It is only a 4 mile drive one way then it sits for 9 hours and then drive it back home and stays parked all day while I sleep.
    2000 Trans Am WS6
    Is it making a whining sound or like a high pitched sound?....The air pump does make a high pitched sound when u first start ur car, and then it goes away, but I can't see it making ur lights go real dim
    Beaver Dam KY
    79 T/A -91 Firebird
    It makes mine dimmer. Not really dim. and when you rev mine kicks off and then kicks on again randomly. I say this is the noise since its a 98. Its loud enough to make people think that i have a maggie under the hood.
    I have a need for speed! jigger1166's Avatar
    Standish,Maine
    Artic White
    00 SS Vert.
    It sounds like the A.I.R. pump. It's inside the L/F fender, in front of the wheel. It's normal.
    SATX
    2000 Trans Am
    its probably your alternator, Mine squeals like a SC sometimes.
    LS1 Wizard 00BadBrd's Avatar
    Foxboro,Ma
    2000 Trans Am
    Check your vac lines going to your throttle body if there collapsed or have a hole/dry rotted it will make a high pitch noise and that would lower your RPM's down enough to causing the alternator not to produce enough amps .... making your lights dim
    Standish,Maine
    Artic White
    00 SS Vert.
    Quote Originally Posted by 00BadBrd View Post
    It would also set the S.E.S. light. So, I don't think that's the prob.
  1. Rear End = High Pitched Noise While Moving
    By theorangeguy in forum Drivetrain
    Last Post: 02-09-2015, 12:45 PM
  2. high pitched "clunk"
    By The Machinist in forum Drivetrain
    Last Post: 12-09-2012, 03:36 PM
  3. High pitched speaker when accelerating?
    By JHayesLS1 in forum Stereo and Electronics
    Last Post: 07-19-2010, 09:56 AM
  4. Help: High pitched whistle noise coming from under hood!
    By Blue99ls1 in forum General Help
    Last Post: 10-08-2009, 06:02 PM
  5. High pitched squeal
    By 00hawk109 in forum General Help
    Last Post: 04-24-2009, 12:35 PM
