    Apr 2009
    Sanford, NC
    2000 Pontiac Firehawk
    High pitched squeal
    So my engine has a high pitched squeal while running. It sounds like it is coming from around the harmonic balancer. What should be my first course of action, replace the belt?
    Feb 2006
    2002 WS6
    how about a better discription. It can also be the air pump.
    Apr 2009
    Sanford, NC
    It really sounds like a squealing belt. Sounds to be coming from around the balancer but its hard to tell, i don't think it's the pump
    Feb 2006
    2002 WS6
    I don't know then, a belt is cheap, there are two, one for the Alt,and a smaller one for the AC
    Feb 2008
    Palm Beach, FL
    440 RWHP / 410 TQ
    2000 SLP CAMARO SS
    Depending on your mileage, a belt change is probably need anyways, so do that and if it still squeals, at least you have limited it down a bit!
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Alright. There are two belts explained above. Two Idlers and Two tensioners. Remove the belt via a 15mm wrench. Spin ALL of the pulleys till you find the sound. If you can find it. Replace the belt. Should cure it.
    USA
    Velocity Yellow
    2008 Corvette Z06
    Possibly AC compressor? See if the noise goes away if you put your heat selector on defrost. If it does, it is the AC clutch. Mine is doing that right now.
    Apr 2009
    ashville n.c.
    is is only at idle or all the time?
  1. Rear End = High Pitched Noise While Moving
    By theorangeguy in forum Drivetrain
    Last Post: 02-09-2015, 12:45 PM
  2. high pitched "clunk"
    By The Machinist in forum Drivetrain
    Last Post: 12-09-2012, 03:36 PM
  3. High pitched speaker when accelerating?
    By JHayesLS1 in forum Stereo and Electronics
    Last Post: 07-19-2010, 09:56 AM
  4. Help: High pitched whistle noise coming from under hood!
    By Blue99ls1 in forum General Help
    Last Post: 10-08-2009, 06:02 PM
  5. High Pitched Noise
    By McCool318 in forum General Help
    Last Post: 04-28-2008, 02:10 PM
