10-01-2009, 08:30 AM #1Junior Member
- May 2009
- Spartanburg, SC
Navy Blue Metalliac- 1999 Z28 Camaro
High pitched whistle noise coming from under hood!
So the other day i was at a fast food dive thru and heard this high pitched whistle! Car runs fine when im on the throttle the noise stops but as soon as i let off the throttle it starts again. Now when the car is in neutral and i rev it up the car hangs out at the rpm that i stop revi g out and slowley cmes back down to normal! I was thinking a vaccum leakor something i cant pinpoint the noise! Anybody have any suggestions! Its a 99 z28 ls1 auto if that matters.
10-01-2009, 08:38 AM #2
10-01-2009, 09:08 AM #3Junior Member
- May 2009
- Spartanburg, SC
Dosent seem to be with the description they gave. Mine is all the time not just after it warms up amd would a belt or tensioner affect the idle part i was describing. The car was running fine till the noise started then the idle thing started.
10-01-2009, 09:11 AM #4Junior Member
- May 2009
- Spartanburg, SC
And mine is not really a chirping sound ive had that before and it was the belts. Mi es is like blowing a high pitched whistle all the time then stop when i push the gas and as lng as im on the throttle it dosent do it but as soon as i let off it starts at any speed
10-01-2009, 01:32 PM #5Junior Member
- May 2009
- Spartanburg, SC
I found out what it was. It is the little piece of hose that goes from the intake manifold on the pass side of the car to what im guessing is the PVC valve. The hose had a hole in it and was melted. I just need to know if anyone knows what the hose is called so i can order a new one.
Heres are links to the pics not the best in the world but its from my iphone
http://yfrog.com/0pimg0090azj
http://yfrog.com/3oimg0091uijLast edited by Blue99ls1; 10-01-2009 at 01:34 PM. Reason: pics didnt show
10-01-2009, 04:42 PM #6Senior Member
- Jul 2006
- Greene, Iowa
Red- 99 Chevrolet Camaro Z-28
just take a chunk of i believe 3/8 inside diameter hose cut to length and slap it on ther....like a .22 cent fix
10-08-2009, 05:46 PM #7Junior Member
- Jul 2009
- Raleigh
White- 1998 Trans Am
Just started having this exact same problem. So what is the verdict?
10-08-2009, 05:53 PM #8Junior Member
- May 2009
- Spartanburg, SC
I did like what was said the post above and replaced it with a piece of 3/4 hose and i havent had any problems so far.
10-08-2009, 06:02 PM #9Junior Member
- Sep 2005
- Orlando, Fl
Primer- 1968 Camaro
Geez... I wish this was posted a couple of weeks ago. I helped a buddy install an single Turbo LS1 in a 2nd gen RX-7. We had the exact same problem. We were convinced that it was metal on metal. So much so that we actually pulled the tranny thinking it was some sort of interference with the flywheel!! I would have bet $100 bucks that it was not a vacuum leak.
I'm glad you got it resolved quickly and without much effort.
Rear End = High Pitched Noise While Moving
By theorangeguy in forum DrivetrainReplies: 20Last Post: 02-09-2015, 12:45 PM -
High pitched speaker when accelerating?
By JHayesLS1 in forum Stereo and ElectronicsReplies: 28Last Post: 07-19-2010, 09:56 AM -
High pitched squeal
By 00hawk109 in forum General HelpReplies: 7Last Post: 04-24-2009, 12:35 PM -
High Pitched Noise
By McCool318 in forum General HelpReplies: 9Last Post: 04-28-2008, 02:10 PM -
High Pitch whistle noise! What can it be?
By NewLS1 in forum Firebird / WS6Replies: 16Last Post: 06-29-2007, 02:56 PM
