    Member nuttyprofessor's Avatar
    New Jersey
    Electrical gremlins...HELP
    Alright....I basically had a draw which was draining my battery. I disconneted my battery and ran my test light from the positive terminal to the now disconnected positive lead. I narrowed it down so that if i disconnect my radio the draw (test light goers off) dissappears. So i ordered a new radio and the same thing is happening. If i disconnect the radio the draw goes away. i tried my neighbors radio and the same thing occurs. I have narrowed it down to the radio itself, but I don't think it is the radio as it happens with different radios, brand new and totally different brand. Can't stand to have my radio disconnected as it will kill the battery in ~3 days...
    Any help/ ideas/ experiences are more then welcome.
    Feb 2006
    2002 WS6
    The radio will draw a small current to keep the memory presets, but it sounds like it is not turning off fully, if you are running a harness adaptor, dissconnect the one for memeory and see what happens, then the one that is supposed to come from a keyed source.
    New Jersey
    It is drawing through the red wire or the keyed source is causing the draw. Shouldn't this end up grounding itself when the key is off?? Where can this circuit be left open? maybe the RAP module?
    Feb 2006
    2002 WS6
    With out seeing how you wired it its hard to tell, but when the key is in the off position there should be no draw. Did you wire in a new supply?
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    dont forget, the bcm will keep the radio on for a few minutes after you shut off the car. Once you open the door it should go off. If it is still drawing I would think that the bcm is bad.
    Member edbird's Avatar
    hammond Ind
    1999 trans am convert
    If you open the door and radio doesn't go off its door switch....mine went bad and caused problems with setting the alarm. If it still doesn't kill power after 8 or 10 minutes after pulling key(regaurdless of door position) I would look at BCM.
  1. Help: Electrical gremlins!?
    By speedyWS6 in forum Firebird / WS6
    Last Post: 06-22-2015, 10:51 PM
  2. Electrical gremlins (headlights, tach)
    By jrbonds in forum General Help
    Last Post: 06-15-2015, 06:59 PM
  3. Help: Electrical Gremlins
    By transAMchubby in forum General Help
    Last Post: 07-11-2009, 04:50 PM
  4. Gremlins??
    By wooddaniel in forum GTO
    Last Post: 04-21-2009, 11:41 AM
  5. help! electrical gremlins!
    By Orange99z28 in forum Stereo and Electronics
    Last Post: 04-24-2008, 02:31 PM
