Results 1 to 20 of 35
    Member BlackSS1's Avatar
    Lexington, NC
    2001 Camaro SS Vert
    ARH Header Install done - pics
    Got em in this weekend: ARH long tubes with catted Y pipe, new NGK iridium plugs, wires, new front O2 sensors too. Hooked it to a Magnaflow catback
    Install was a PITA but I suck at mechanical work. Took 14 hours with a buddy helping for most of that time. You may do it much faster.
    Total $1700
    Worth the trouble and money - sounds incredible and nice bump in power.
    Make real real sure Johns00Z28's Avatar
    Germantown, MD
    2000 Z-28
    Nice looking setup...congratulations.
    Union Beach, NJ
    triple black
    02 z28 m6
    excellent, thats what i plan on putting on my new engine whenever i get everything together.
    looks good...congrats.
    Member hoss 2000 z-28's Avatar
    Jeffersonville, Indiana
    Monterey Maroon Metalic
    2000 Z28
    Congrats on a job well done. The satisfaction of doing it yourself makes it much more enjoyable. Try and post a sound clip soon!
    Gainesville, VA
    Did you use a lift or just jack stands? When money permits this is the set up I would like to go with looks very nice.
    Lexington, NC
    2001 Camaro SS Vert
    Thanks for all the comments. I'll post up a video/sound clip soon.
    I used a floor jack, blocks of wood, and some monster 24" truck jack stands. I had it up 20" from the floor and the headers went in pretty easily.
    Fort Wayne, IN
    2002 Chevy Camaro SS LE
    ARH Header install
    Hello,
    This is exactly what I want to buy for my 02 SS LE. Can you please elaborate on what was such a PITA? How do the headers and catted y-pipe fit? How is the ground clearance? Were there any modifications that you had to do? Thank you very much.
    Lexington, NC
    2001 Camaro SS Vert
    Hey KCC, sure:
    Here is the PITA part:
    plug wires seized onto the plugs, 2 hours yanking, yelling, finally ripping the old wires into shreds to get on with it. Definately get the dielectric grease for $1 to prevent this when you change plugs/wires!
    Engine compartment is really tight. You have to be really creative and use extensions, Universal ratchet joints, and lots of patience to get to everything. BUY THE 10MM GEAR WRENCH EVERYONE MENTIONS.
    Screw-ups like putting the gasket on wrong, then having to remove the header bolts and reinstall it again
    The good stuff - header quality is just about perfect, and fit great. No metal work or sawsall necessary for my install. The pipes fit together just like you want. Clearance was very good for a catted pipe. I have not measured, but it does not appear to hang much lower than the stock Y pipe. I took it over a speed bump that usually required caution with stock pipes, and it did not scrape. I had to pitch the stock transmission tunnel brace - probably getting a Spohn aftermarket one with more clearance.
    I highly recommend these headers. You could not ask for better quality or fit.
    Fort Wayne, IN
    Thank you very much for the info. Do you have a source that you recommend purchasing them from? Is the 10MM GEAR WRENCH a short or long wrench and what is this used for? From the pics it looks like you may have had some kids helping you with the install, which makes it more memorable if not faster. Thanks again.
    Lexington, NC
    2001 Camaro SS Vert
    MPH Motorsports is where I bought them. The gear wrench is a small one to reach the back header bolts, coil pack bolts and other stuff. Very handy to turn bolts that you cannot see in tight spaces.
    My kids did not help, they just leave toys and junk all over the garage all the time. After a few years, kid junk has become invisible to me
    Florida
    2002 Trans Am WS6
    LMAO @ kid junk! Very nice setup btw.
    Lexington, NC
    2001 Camaro SS Vert
    Thanks no garage is complete w/o some kid junk
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Quote Originally Posted by BlackSS1 View Post
    Nice work, and man, those are some nice looking headers.
    Lexington, NC
    2001 Camaro SS Vert
    Thanks. They are pretty nice for the price, and less $$$ than Kooks
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Nice job! As far as the 14 hours go, would you do it all over again?
    Delaware
    1999 z-28 convertible
    Looks good, I have the same setup sitting on my office floor waiting for me to get off my lazy butt.
    Lexington, NC
    2001 Camaro SS Vert
    Quote Originally Posted by GatorSS View Post
    Thanks! Yes definately. It is satisfying to do stuff on your car yourself, and you know 100% that is done right. Plus it is an excuse to buy nice tools you would not otherwise buy.
    Lexington, NC
    2001 Camaro SS Vert
    Quote Originally Posted by mcflysz28 View Post
    I just got a buddy to help me, really helps to spread the work across two guys... best of luck with your install
    You will be pleased with the set when you get them in
    Charlotte, NC
    Sebring Silver Metallic
    2002 Z28
    And the big question...
    Definitely gorgeous headers and a good-looking job. But how's the buttometer reading? Pretty noticeable? Going to get/need a tune?
  1. Install shop or DIY header install?
    By dethinboots in forum External Engine
    Last Post: 09-24-2011, 06:35 PM
  2. header install in pics
    By sjsingle1 in forum External Engine
    Last Post: 07-02-2011, 10:59 PM
  3. Header Install in Pics (Pt 2)
    Last Post: 05-09-2010, 02:14 AM
  4. Post LT header install header issues
    By ob02z28 in forum External Engine
    Last Post: 02-18-2010, 04:10 PM
  5. Header install?
    By richard head in forum External Engine
    Last Post: 10-29-2007, 11:25 AM
