Thread: Header install?
10-28-2007, 03:41 PM #1Member
- Feb 2007
- austin
Black/Black- '00 Firebird WS6 T/A
Header install?
I put a set on my old v6... it was a nightmare. Busted off a bolt in the head, out of reach, took it to a shop which failed to get it out and still charged me $100... etc. I noticed that this car seems to have studs instead of bolts holding on the stock mani's, so how many of you guys have busted bolts doing this?
Cliff notes: Anybody bust a bolt off during a header install?
10-28-2007, 04:25 PM #2
there's a can of stuff similar to wd-40 you buy at an autoparts store which seeps into the rusty manifolds and makes it alot easier to losen the bolts
10-28-2007, 04:29 PM #3
10-28-2007, 07:51 PM #4
mine came out real easy, they are not studs tho, they are bolts
10-28-2007, 08:06 PM #5
There bolts, except for the manifold to cat's those are studs and mine broke but there were coming off anyhow so it wasnt an issue. make sure if you do use lubricant like mentioned above you blow out the bolt holes.
10-29-2007, 11:25 AM #6Member
- Aug 2007
- Iowa
Red- 2000 SS
Didn't break any but cross threaded one going back in. Oops.
Install shop or DIY header install?
By dethinboots in forum External EngineReplies: 7Last Post: 09-24-2011, 06:35 PM -
Post LT header install header issues
By ob02z28 in forum External EngineReplies: 20Last Post: 02-18-2010, 04:10 PM -
header install so cal?
By sscamed in forum External EngineReplies: 0Last Post: 10-26-2008, 11:18 PM -
Header install, other
By Tide in forum GTOReplies: 0Last Post: 03-07-2007, 08:01 AM -
Header install
By linegtdt52 in forum Parts ReviewReplies: 9Last Post: 03-09-2006, 12:05 PM
