Results 1 to 20 of 124
Thread: header install in pics
03-20-2010, 01:23 PM #1Senior Member
- Jan 2010
- texas
silver- 2000 formula
step 1......delete EGR
two 15 mm bolts on head......one 10mm bolt on intake (its a 2000) and two 10mm bolts on pass side exh manifoldLast edited by sjsingle1; 03-24-2010 at 03:42 PM.
03-20-2010, 01:24 PM #2Senior Member
- Jan 2010
- texas
03-20-2010, 01:24 PM #3Senior Member
- Jan 2010
- texas
03-20-2010, 01:25 PM #4Senior Member
- Jan 2010
- texas
03-20-2010, 01:26 PM #5Senior Member
- Jan 2010
- texas
03-20-2010, 01:26 PM #6Senior Member
- Jan 2010
- texas
new GM EGR block off.....or you can use 1 3/8 expandable rubber freeze plugLast edited by sjsingle1; 03-24-2010 at 03:43 PM.
03-20-2010, 01:27 PM #7Senior Member
- Jan 2010
- texas
03-20-2010, 01:28 PM #8Senior Member
- Jan 2010
- texas
air tube removed from drv side exh manifold and header bolts removedLast edited by sjsingle1; 03-24-2010 at 03:44 PM.
03-20-2010, 01:29 PM #9Senior Member
- Jan 2010
- texas
air pump under driver side fuse boxes.....HINT....underneath carLast edited by sjsingle1; 03-24-2010 at 03:45 PM.
03-20-2010, 01:30 PM #10Senior Member
- Jan 2010
- texas
drv side motor mount set up.....BIG HINT....remove and leave out til you have header in.....remove ALT to reach mount boltsLast edited by sjsingle1; 03-24-2010 at 03:47 PM.
03-20-2010, 01:30 PM #11Senior Member
- Jan 2010
- texas
diverter valve ....GONE....and you can see the DV selniod in the upper left corner....where you need to cap off the vacum lineLast edited by sjsingle1; 03-24-2010 at 09:52 PM.
03-20-2010, 01:31 PM #12Senior Member
- Jan 2010
- texas
anybody know why right above the filter is a freakin oily mess.....cant see it from here......but its badLast edited by sjsingle1; 03-20-2010 at 11:52 PM.
03-20-2010, 01:32 PM #13Senior Member
- Jan 2010
- texas
remove drv side heat shield for extra room and keep from tearing up arms and hands.....two 7mm boltsLast edited by sjsingle1; 03-24-2010 at 03:48 PM.
03-20-2010, 01:33 PM #14Senior Member
- Jan 2010
- texas
DV bracket is held on by one 10mm bolt on coil pack and one 15mm bolt on back of head.....YES it can be reached......YES its a PITA.....think gearwrench......and that hard plastic line.....where it leads to the DV selnoid needs to be capped.....i got a assortment of vacum caps at pimp boys.....it was a small one.....OR....you can remove the DV selnoid....and then plug the vacum line at the back of the manifoldLast edited by sjsingle1; 03-24-2010 at 09:50 PM.
03-20-2010, 01:33 PM #15Senior Member
- Jan 2010
- texas
air pump out.....four 10 mm boltsLast edited by sjsingle1; 03-24-2010 at 03:50 PM.
03-20-2010, 01:34 PM #16Senior Member
- Jan 2010
- texas
air pump.....GONELast edited by sjsingle1; 03-20-2010 at 11:47 PM.
03-20-2010, 01:35 PM #17Senior Member
- Jan 2010
- texas
bolts to k member.....four 15mm.....bolt on MM......18mmLast edited by sjsingle1; 03-24-2010 at 03:51 PM.
03-20-2010, 01:35 PM #18Senior Member
- Jan 2010
- texas
new poly mounts and spohn lightweight mountsLast edited by sjsingle1; 03-20-2010 at 09:07 PM.
03-20-2010, 01:36 PM #19Senior Member
- Jan 2010
- texas
03-20-2010, 01:37 PM #20Senior Member
- Jan 2010
- texas
grind rivets off of old clamshell.....what fun.....remove nasty shrunken GM rubber......cleanup.......i put grease on polys to make them fit in the clamshells easier.....bolt down with 2 bolts.............top and bottomLast edited by sjsingle1; 03-24-2010 at 03:54 PM.
Install shop or DIY header install?
By dethinboots in forum External EngineReplies: 7Last Post: 09-24-2011, 06:35 PM -
Header Install in Pics (Pt 2)
By sjsingle1 in forum External EngineReplies: 36Last Post: 05-09-2010, 02:14 AM -
Post LT header install header issues
By ob02z28 in forum External EngineReplies: 20Last Post: 02-18-2010, 04:10 PM -
ARH Header Install done - pics
By BlackSS1 in forum External EngineReplies: 34Last Post: 05-15-2008, 03:35 AM -
Header install?
By richard head in forum External EngineReplies: 5Last Post: 10-29-2007, 11:25 AM
