Results 1 to 16 of 16
    Mississippi
    2001 Trans Am
    Angry Help! What is rattling?!?!
    Here's what's happening... when I accelerate I hear a rattle (not everytime, only about 3 times per week), sounds almost like a tin can dragging. I have even gotten out and looked under the car just to make sure. Nothing there. I have had the muffler(s) checked, new cats, tune-up, all 02 sensors replaced, new brakes-discs and rtrs. Nothing shows up as wrong on the dealership computer and no probs. with the temp. and it's shifting fine (automatic). Nothing is loose underneath either. WTF is it??
    Also, does anyone know of a good mechanic in the Memphis/North MS area? I need to have some a/c work done and do not want to get ripped. I need a condenser and dryer replaced and was just told there is a little rust in the radiator. Thanks!
    let the F-Bodies roll jimmybling31's Avatar
    hixson tennessee
    94 camaro z28
    do you lt's if so it might be them hitting
    Senior Member rajiv1998's Avatar
    New Jersey
    1998 Pontiac Trans Am
    Is ur exhaust modified? Maybe the y-pipe is lose.
    Mississippi
    2001 Trans Am
    The exaust is stock. Could that still be a problem? Thanks!
    Mississippi
    2001 Trans Am
    Quote Originally Posted by jimmybling31 View Post
    Dcdrummer LS1buckey's Avatar
    Delaware, Ohio
    pewter
    1999 Pontiac Trans Am
    Quote Originally Posted by BdAsBrd01 View Post
    just incase the ??? was you not understanding what was said he means do you have long tube headers? which you already said your exhaust is stock so dont worry about it I had that problem with my headers. I suppose the manafolds could be rattling though.
    Mississippi
    2001 Trans Am
    Quote Originally Posted by LS1buckey View Post
    Thanks, I appreciate it. Wasn't sure what he meant.
    Senior Member Rhinohuey's Avatar
    Glendale, AZ
    1999 Trans Am
    Theres a real good chance this isn't it, but you might check your passenger seat springs.....I know it sounds crazy, but a few months back I heard a sound that I could swear was something metal dragging under the car and then I put my hand over on the passenger seat and it stopped. They made a rattling sound like something dragging under the car when they would vibrate.
    Mississippi
    2001 Trans Am
    Quote Originally Posted by Rhinohuey View Post
    Thanks, I'll check that too. I'm not ruling out anything at this point. Its weird and hasn't happened with one of the mechanics in the car so they have no clue.
    Senior Member GULLETT17's Avatar
    Muncie, IN
    00 TA PWTR, 98 VertTA NBM
    80 TA BLK, 80 Formula NBM
    ive have a similar sound that started after my transmission was rebuilt . . . mine only happens on acceleration and at about 1500-2500 rpms. i was thinkin it was a heat shield but have never found one that seems loose enough
    Member Mike's TA's Avatar
    Austin, TX
    99 Trans Am(sold)
    Is it constant or just for a moment?
    Parma Heights, Ohio
    SOM
    99 Trans Am
    Could be the honeycomb in your cats..
    Tire Punisher josepy121380's Avatar
    Wisconsin
    2002 Trans Am WS6 M6
    mine did the same thing. its probably your cats. when i took mine off and put the lt's on. my cats were loose.
    Mississippi
    2001 Trans Am
    Quote Originally Posted by Mike's TA View Post
    It's just for a moment and only when accelerating below 45.
    Austin, TX
    99 Trans Am(sold)
    Is it only when you first start, or does it happen at all after you've been running for awhile.
    What I'm getting at is. Every once and awhile I hear what sounds like a tin can hitting the ground as well, but very loud and I know that it is my exhaust. Got louder after I hollowed out my muffler. Are you absolutely certain that it's not your exhaust? Pay attention to your rpms. If it's in the middle of a shift then you will know that it's your exhaust. It's easier for me to tell cause I'm manual and can wait before excellerating again.
    Member Stricken1's Avatar
    Florida
    2001 Trans Am WS6
    I had an annoying rattle and it turned out to be the jack was lose. I dont have the spare in there anymore but I left the jack in. I tightened it down and the rattle went away.
  1. Rattling cat?
    By Spikito in forum External Engine
    Last Post: 05-26-2011, 06:41 PM
  2. car rattling
    By ss2000 in forum Suspension and Handling
    Last Post: 04-21-2010, 06:31 PM
  3. Help rattling speakers
    By 1fastz28 in forum Stereo and Electronics
    Last Post: 03-12-2010, 06:56 AM
  4. Something is rattling!!!!!
    By Ryanater in forum Manual Transmission
    Last Post: 11-01-2007, 11:46 PM
  5. New Slp LM II rattling!!!
    By matt123 in forum General Help
    Last Post: 02-22-2007, 09:19 AM
