Thread: New Slp LM II rattling!!!
01-29-2007, 02:43 PM #1Junior Member
- Oct 2006
- NJ
Red- 01 z28
Just had this catback installed last week and it's rattling a lot. Brought it back and stopped for a day, and now rattling more than ever. Any one else have this problem? Any ideas of what to do?
01-29-2007, 02:59 PM #2
01-29-2007, 03:15 PM #3
yeah sounds about right. i was able to loosen the clamps and adjust the pipes (i have the modular system) and then tighten the sh!t out of the bolt to the frame over the rear axle. problem solved...
2013 ZL1: °°590rwhp/576rwtq°°
01-29-2007, 03:33 PM #4
Does the SLP Loudmouth utilize 3 mounting points behind the axle?
01-30-2007, 06:07 AM #5
there is one location around the real axle that it bolts too the frame or underneath of the car. then you have two exhaust hanger brackets (one on each side) that the rest of the system hangs on too. that's it. so yes 3 locations like you have asked...
02-19-2007, 07:38 PM #6Junior Member
- Oct 2006
- NJ
Red- 01 z28
I m not sure about heating it and hitting it with a hammer. I can see it breaking or something, tend to have bad luck. What if I wrap that part in header wrap? Would that keep the rattling down? It would no longer be metal on metal. Any input appreciated.
02-20-2007, 09:46 AM #7
Heat it and bend it. It will not break!
02-22-2007, 09:19 AM #8Member
- Feb 2007
- FairField, CA
RED 35TH ANIVERSARY PKG- 2002 CAMARO SS 35th LE
I Have The Slp Factory Exhust.. And I Did Notice Rattling Sometimes The Best Thing I Can Tell You Is Check For Loose Bolts..!! My Is Already 5yrs(2002) Old Bolts Loosen Over Time.. So Try Check The Bolts And Tightin Them.. All The Bolts That Connect The Clamp To The Exhust.. So Double Check Them.. If That Doesn't Work Then You Probably Have A Something Else Wrong
Rattling cat?
By Spikito in forum External EngineReplies: 8Last Post: 05-26-2011, 06:41 PM -
car rattling
By ss2000 in forum Suspension and HandlingReplies: 4Last Post: 04-21-2010, 06:31 PM -
Help rattling speakers
By 1fastz28 in forum Stereo and ElectronicsReplies: 9Last Post: 03-12-2010, 06:56 AM -
Help! What is rattling?!?!
By BdAsBrd01 in forum Firebird / WS6Replies: 15Last Post: 03-25-2008, 02:24 PM -
Something is rattling!!!!!
By Ryanater in forum Manual TransmissionReplies: 12Last Post: 11-01-2007, 11:46 PM
