Thread: car rattling
    los angeles
    blue
    2000 camaro
    car rattling
    ok ls1, just changed my shocks and springs(koni/strano) when i roll over bumps my car still rattles what wil cause this to stop.
    Lots of things to look at -- I would start with the exhaust clearance over the panhard brace, all the undercar heatshields, and possibly the spare tire, jack and such.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Agreed on the heat shield and exhaust. Depending on what exhaust set-up you have, where the pipe crosses over the axle gets "very" close to the panhard bar as Jeff mentions. You should be able to tell if it's rubbing there by looking at the metal itself on the exhaust.
    Mine used to hit and I created some clearance with a prybar . Now I have the PHB relocation kit from UMI. Will be installing it soon.
    I gained some additional clearance by sliding the mid-pipe back a bit on the Y -- about 1/4 inch was all it took to comfortably clear the panhard brace. Will you post up some pics of the install Jon?
    los angeles
    blue
    2000 camaro
    thanks i will check everything. it sounds like its the plastic pieces in my car mainly near the rear.
  1. Rattling cat?
    By Spikito in forum External Engine
    Last Post: 05-26-2011, 06:41 PM
  2. Help rattling speakers
    By 1fastz28 in forum Stereo and Electronics
    Last Post: 03-12-2010, 06:56 AM
  3. Help! What is rattling?!?!
    By BdAsBrd01 in forum Firebird / WS6
    Last Post: 03-25-2008, 02:24 PM
  4. Something is rattling!!!!!
    By Ryanater in forum Manual Transmission
    Last Post: 11-01-2007, 11:46 PM
  5. New Slp LM II rattling!!!
    By matt123 in forum General Help
    Last Post: 02-22-2007, 09:19 AM
