Results 1 to 19 of 19
03-19-2008, 09:01 AM #1Member
- Feb 2007
- Bakersfield, CA
86 Buick Grand National- 02 WS6-M6 407 RWHP
Where to buy t/b coolant bypass kit?
Where can i buy the t/b coolant bypass kit from for cheap, i know bmr fab sells them for sixteen bucks but thats way more than that 3 dollar kit should be marked up. Figure it be easier just buying a kit than tracking all the parts down for it myself in town.
Also where's a right up on the free ram air mod?
03-19-2008, 09:08 AM #2Senior Member
- Oct 2007
- Muncie, IN
00 TA PWTR, 98 VertTA NBM- 80 TA BLK, 80 Formula NBM
hmm. . . ebay and im pretty sure one of our sponsor's sells it
03-19-2008, 09:48 AM #3
I made mine from home depot. I just uses a 3/8 male to male barbed fitting and connected the hoses together
03-19-2008, 09:52 AM #4
03-19-2008, 11:25 AM #5
ebay, got mine for like 8 bucks including shipping
03-19-2008, 11:50 AM #6
03-19-2008, 12:07 PM #7Junior Member
- Jan 2008
- ohio
white- 99 trans am convertible
reply
03-19-2008, 01:18 PM #8Member
- Feb 2007
- Bakersfield, CA
well off it is to home depot then, thanks guys.
Can anybody give me a link to the free ram air mod.
I'm doing this stuff backwards usually people do all the free mods first but i never really planned on doing them. Just bored and feel like messin with the car.Pacesetter Headers- ORY
Texas Speed 228R Cam/Moly Pushrods/918 Springs
MTI LID
Slp Under Drive Pulley
Texas Speeds Rumbler Catback
SFC's, Lakewood LCA's
Koni SA 4/3, Strano Springs
Dyno Tune
LS7 Clutch, Nitto DR's
407 RWHP 377 Ft./lbs.
03-19-2008, 06:40 PM #9
Here is the link to the mods: http://www.chevyhiperformance.com/te.../photo_06.html
and more:
http://www.ultimateresourceguides.co...-freemods.html
I'm in the process of testing a TBC (TB Cooler) which not only bypasses the heated radiator fluid, but gets cooled through its own radiator. Coolant is circulated via an electric in line pump and heater hose that connects everything. WARNING: Don't use this below freezing temps! I will post Dyno results and pics on our club site when I finish. Here:
http://tteedd.hostsnake.com/tech.html
Good Luck!
03-19-2008, 08:58 PM #10
good luck with them super chevy did all the free mods in their magazine and gaind 10rwhp in a stock camaro and im pretty sure the article says how to do all of them just google it.
03-19-2008, 09:07 PM #11Impounded
- Oct 2007
- Beaver Dam KY
I found a peice of metal fuel line in my shop. and i found two hose clamps. works fine.
03-19-2008, 09:13 PM #12rapter34Guest
and as for the free ram air mod check out http://installuniversity.com/
03-20-2008, 07:11 AM #13Member
- Nov 2007
- SATX
Pewter- 2000 Trans Am
speaking of free mods, did anyone hear about switching the oilfilter causes a 10hp gain? our OF is PF46(delco) and if you use a PF61 it adds 10 Hp, well i did it and i felt it but it could of been gas :P can anyone confirm it?
03-20-2008, 08:06 AM #14Member
- Feb 2007
- Bakersfield, CA
I really hope your kidding, the bigger oil filters simply filter the oil better.
03-20-2008, 10:58 AM #15Impounded
- Oct 2007
- Beaver Dam KY
hah
03-20-2008, 11:33 AM #16
SLP Magnets will add +5 RWHP!
Kidding
03-20-2008, 05:10 PM #17Import Killer
- Sep 2005
- MIchigan
Navy Blue Metallic- 2000 Camaro SS
I used an old dipstick tube, Cut a 4-5 inch piece out of the straight part and used 2 hose clamps!
03-23-2008, 10:39 AM #18
03-23-2008, 12:31 PM #19
+15 hp SLP decal
Not that I'm starting trouble, but your WRONG! 20+rwhp w/SLP decal if you put it on exhaust manifold.....hahahahaha!
throttle body coolant bypass Q
By tomcamaro97 in forum External EngineReplies: 7Last Post: 06-18-2014, 02:33 PM -
Coolant bypass lines/plugs LS6 Swap
By Vertiviper in forum External EngineReplies: 10Last Post: 04-25-2010, 02:42 PM -
Throttle Body Coolant Bypass
By CamaroDMD in forum External EngineReplies: 7Last Post: 04-28-2008, 04:20 PM -
TB Coolant Clamps (for bypass)
By Rocky Rotella in forum General HelpReplies: 4Last Post: 05-20-2007, 11:41 AM -
coolant bypass???
By bobbert350 in forum External EngineReplies: 32Last Post: 04-22-2007, 07:02 AM
thats pretty cheap
