    LE #2823 CamaroDMD's Avatar
    Oregon
    Red with Silver Stripes
    2002 Camaro SS LE
    Throttle Body Coolant Bypass
    OK, so I bought my 2002 Camaro SS LE a couple weeks ago and one of the modifications (really the only one) the previous owner did to the car was to bypass the throttle body's coolant line. He said that it is supposed to increase horsepower. Does this actually work? Also, do you compromise fuel efficiency at the same time?
    Basically, should I leave it like this or put it back?
    1969 Chevrolet Camaro SS396 (Clone)
    2002 Chevrolet Camaro SS LE#2823 SLP M6
    Member 35thz28camaro's Avatar
    mobile
    2002 z28 camaro
    leave it, coolant runs through the the TB to keep it from sticking(witch will probably never happen) on reel cold day, bypassing it keeps the TB cooler, witch keeps the air cooler; it will not effect gas millege at all
    Aug 2006
    Missouri
    94 Camaro Z28
    I would put a vacuum cap on that coolant tube on the TB. It will just keep it clean just in case you want to reverse it later or sell it for a bigger one.
    Make real real sure Johns00Z28's Avatar
    Germantown, MD
    2000 Z-28
    I would leave it alone....one less mod you'll have to do in the future.
    Member fxgs's Avatar
    Camp Hill, Pa
    Onyx Black
    2002 SLP Camaro SS
    Quote Originally Posted by CamaroDMD View Post
    yea right..........maybe.05 rwhp. Just kidding...........did the same to my SS..........don't worry, leave it as it won't hurt anything and who knows..........maybe help a little.
    And cap those open ends, please.
    Junior Member Acceleration Junky's Avatar
    Long Island, N.Y
    sunset metallic orange
    2002 Z28
    The theory is to heat up the throttle body in cold weather and to cool off the throttle body in hot weather. That's why coolant runs through the throttle body as per GM's 02 service manual. I have no idea if it is a good or bad thing to bypass it. I would definitly cap those pipes if you decide to leave it.
    San Diego ca
    "Arrest Me Red"
    2001 trans am
    when the moter is cool it dont do any good but when it gets hoter you heat the incoming are and lose some power when you bypass it you are just keeping that power so just keep it the way it is now you alread have a free mod done but ya caps would be a good thing
    Member jujofields's Avatar
    Lafayette, Indiana
    Pewter Metallic
    2002 Trans Am WS.6
    Yep, good free mod to keep the air going into the TB from getting hot/hotter.....the only time I could see it as a problem would be if you plan on driving your car when it starts getting really cold outside.....
  1. throttle body coolant bypass Q
    By tomcamaro97 in forum External Engine
    Last Post: 06-18-2014, 02:33 PM
  2. throttle body bypass on lt1
    By jimmybling31 in forum External Engine
    Last Post: 03-18-2008, 05:28 PM
  3. Throttle Body Bypass?
    By Demon_Z28 in forum External Engine
    Last Post: 03-10-2008, 03:42 PM
  4. throttle body bypass............
    By clg82 in forum Firebird / WS6
    Last Post: 04-29-2007, 12:54 PM
  5. Throttle body Bypass kit ? 6-8hp?
    By jinxeng in forum External Engine
    Last Post: 09-18-2006, 08:37 AM
