Results 1 to 20 of 33
Thread: coolant bypass???
04-17-2007, 12:32 PM #1
coolant bypass???
I have a 2001 Camaro SS and i was wondering what parts are needed for coolant bypass on the stock throttle body.
04-17-2007, 02:32 PM #2
short list; two small hose clamps, two barbed hose fittings and a union to connect the hose fittings together, not sure on the sizes though.
04-17-2007, 02:35 PM #3Senior Member
- Jul 2005
- Jacksonville, FL
Is this really worth doing?
04-17-2007, 02:41 PM #4
no, all it does is slightly reduce the temperature of the throttle body due to the hot coolant flowing through it, but if you think about it the engine heats it up anyways
04-17-2007, 02:42 PM #5
you will not feel a difference if you do it, just more chances of having a coolant leak or air in the system
04-17-2007, 03:57 PM #6
It is worth it, its a free mod and has gains of a dyno proven 7rwhp. Not saying everyone will get 7 rwhp, but you should get a few.
04-17-2007, 04:00 PM #7
7 horsepower my ass, maybe 2 , but remember dynos are not that consistent, neither is the performance of your car, so unless you gain 15+ hp from something, you cant be sure of your results due to the error that appears between runs
04-17-2007, 06:35 PM #8
I've done this mod but have not felt any hp gain. It was a free mod and didn't take long at all to do so I just did it.
04-17-2007, 06:57 PM #9
Here's a LT1 dyno from WS6.com after coolant bypass http://www.bmrfabrication.com/tb-dyno.htm . It probably only makes 2-5 real world HP on the LS1, but it's cheap and easy to do. Every little bit counts.
I used the kit from here http://www.bmrfabrication.com/misc.HTM just so I didn't have to find the materials. I also liked the fact that it came with a billet aluminum connector and dust caps to seal off the TB pipework and keep junk out of it. All you need are 2 hose clamps and a piece of pipe small enough to fit into the hoses.
I bypass year round, since my car is garaged and never driven in cold weather. Some people prefer to bypass in the spring/summer/fall and not to bypass in the winter.Last edited by jag42420; 04-17-2007 at 07:02 PM.
04-17-2007, 07:09 PM #10
www.vincihighperformance.com sells it for $9.95
04-17-2007, 07:11 PM #11
Wish I would have seen it there first....
04-17-2007, 07:32 PM #12
1 rwhp confirmed on numerous dyno tests
http://www.ls1howto.com/index.php?article=13
04-17-2007, 07:38 PM #13
Which would be 1rwhp more than you started with, for relatively no cost.
04-17-2007, 09:11 PM #14
Not to mention, it is that much easier to take the tb off in the future cuz there are no coolant lines attached.
04-17-2007, 09:16 PM #151999 Trans Am M6
SLP Short Throw, Lid and CAI, Strano Springs, Koni Sport Shocks, BMR STB and SFC, UMI PHB, Pacesetter LT's and ORY, Magnaflow Catback, DMH 3" E-Cutout, LS7 Clutch, Motive 4.10, 160 T-Stat, MSD wires,, 17x9.5 Chrome C6's wrapped in Hankook 275/40/17
Tuned at Mongillo Motors in New Haven, CT - 303 RWHP and 308 RWTQ
04-17-2007, 09:58 PM #16
lol 1hp...thats right up there with a k&n air filter. if you are gonna go buy parts and do this you might as well save some $ and just buy 1 long piece of hose and attach it with the stock clamps. it'l save you time and money of using connectors and have less places for a possible coolant leak/ bottleneck. i've seen posts where people just used 1 long piece of (i think) 5/16 hose made it fit.
04-18-2007, 04:10 AM #17
I just read that article. It doesn't actually have any data or dyno testing. It simply claims "there is no noticable gain from this mod, but a few people have consistantly run 1-2hp more on a dyno after this mod".
The problem with assigning a 'coolant bypass = x HP' is that there are not enough dyno tests out there to provide the proof. If you're running a CAI or a SS/WS6 with a sealed hood, you're going to get a little bit more from this mod. Why go through the trouble of using a CAI, just to have the air warmed back up at the TB? The LT1 dyno tests from WS6.com http://www.bmrfabrication.com/tb-dyno.htm , for example, showed an average gain of 5 more HP consistently with a peak gain of 6.3 HP.
While any way you slice it this is not a seat of the pants mod, it does in fact add power. Google search for coolant bypass and see what you get. No one doubts this adds power, just how much. The only F-body dyno test I can find shows 5HP average gains. Every 1 HP added is like dropping 10# from the car. Considering this mod is easy, quick, and cheap, I'd recommend it to anyone wanting to maximize HP.
04-18-2007, 05:10 AM #18
04-18-2007, 08:31 AM #19Member
- Jan 2006
- incognito
this has to be one of the most useless mods to the ls1. its a waste of time and thought. this is something a guy driving a fucking honda with a 4" tip would do to his car. puuleeaase
04-18-2007, 10:09 AM #20
throttle body coolant bypass Q
By tomcamaro97 in forum External EngineReplies: 7Last Post: 06-18-2014, 02:33 PM -
Coolant bypass lines/plugs LS6 Swap
By Vertiviper in forum External EngineReplies: 10Last Post: 04-25-2010, 02:42 PM -
Throttle Body Coolant Bypass
By CamaroDMD in forum External EngineReplies: 7Last Post: 04-28-2008, 04:20 PM -
Where to buy t/b coolant bypass kit?
By sfletch2000 in forum General HelpReplies: 18Last Post: 03-23-2008, 12:31 PM -
TB Coolant Clamps (for bypass)
By Rocky Rotella in forum General HelpReplies: 4Last Post: 05-20-2007, 11:41 AM
