    Member ledesma54's Avatar
    Houston
    04 GTO
    Would i be running lean
    I have a 04 gto why would my car be getting 12.9 mpg( i think i might be running lean but wouldn't it throw a code). I have long tube headers, a diablo tune, a cold air intake, a bigger Mass air Flow, and a pair off one chamber flow-masters. What do u think. Also when i try to lanch at about 1300 rpm it kinda sputters before taking of whats up with that do i need to up my lunch point or is something wrong.
    Reno
    2004 GTO
    It sounds rich if anything. 12.9 mpg is bad. Unless you're WOT every other run.
    You might try launching at say...3500-4k rpms.
    Retired Outlaw Sum Bitch
    Often times it is bad O2 sensors making you run so rich.
    Member Spieldawg's Avatar
    BeaverCreek OH
    Phantom Black Metallic
    2004 GTO M6
    Hmm. I had the same problem before my tune, my car was wanting 10-15 percent more fuel in the low to mid rpms. Also what headers do you have, and if they are pacesetter's did you splice and lengthen the wires or did you buy 02 extensions??
    http://www.ls1.com/forums/image.php?type=sigpic&userid=37788&dateline=120321  7751
    2004 M6 Phantom Black with Red Interior.
    13.4 @ 104 MPH 1/4 mile
    www.teamgto.org
    http://www.cardomain.com/ride/2653972
    http://www.fquick.com/spieldawg
    OK we fixed his wiring problem ( via PM's) .....He either has a bad sensor signaling for more fuel or his tunes is crap. I told him to replace the sensors and reset the ECM. IF it is still running rich it is the tune.
    Maggie Blown 04 GTO AUSI GTO's Avatar
    Bradenton, Fl.
    2004 GTO Maggie Blown
    Get it on a dyno and check the a/f with a w/b and have it tuned there also.
    BeaverCreek OH
    2004 GTO M6
    I ended up soldering mine, and now they work like a champ.... I don't believe the sensors are bad.. its the crimp splices...
  1. Running lean
    By MeanMachine1 in forum Internal Engine
    Last Post: 11-22-2012, 02:33 PM
  2. running lean
    By occamaroz in forum Computer & Tuning
    Last Post: 12-05-2009, 06:00 PM
  3. Running lean
    By emotionalpiracy in forum External Engine
    Last Post: 11-13-2007, 11:34 PM
  4. Running too lean
    By ddouds2000 in forum General Help
    Last Post: 01-03-2007, 09:27 PM
  5. running lean ??
    By wukash in forum LT1
    Last Post: 08-13-2006, 07:32 AM
