Results 1 to 10 of 10
Thread: Running lean
    Mar 2012
    MICH
    Black N Gold
    02 WS6 / Ls6 with mods.
    Running lean
    Ok so bought my 02 WS6 29k orig mi with a brand new ZO6 LS6 in it pretty much stock except for a Comp cam headers and a couple other things. Anyway engine light came on so I just took it to Autozone to get an idea of what was going on . The code said bank 1 & 2 lean . My question is do I have to find a special Tuner / Dyno since the motor is not stock ? Or can I just take it to a Reg mech to have this fixed ? I put about 1400 mi on the car and new motor so far with no issues , overall the motor only has about 1500 mi on it.
    Thanks
    phoenix
    04 2500 4x4 crew cab
    You would be better off finding a shop that does a lot of fbodys, but really any good mechanic should be able to help you.
    Your friendly policeman FinZ28's Avatar
    Jan 2012
    Alabama
    Bright Rally Red
    2001 Chevy Camaro Z28
    Sounds like you need a tune since you mentioned you have a cam. Check with Frost. He's a site sponsor and can get you pointed in the right direction.
    2001 Chevy Camaro Z28 A4
    SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
    Coral Springs, Fl
    Sunset Orange Metalic
    Quote Originally Posted by FinZ28 View Post
    Agreed, when there is modification involved a specialist is the best bet
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Let Steve do the job, he is one of the best with F-Bodies. BTW, just got our 2004 GTO computer back. Installed in a few minutes and let the wife, 51 years young, drive it for reprogram and it now runs and shifts (AUTO) fantastic. We drove out to PA on 84 West and nobody on the road. Down goes the gas pedal and the car just flew. Before we knew it we were doing 130mph. Thank you Steve. My wife fell in love with her Goat all over again.
    Indianapolis
    2000 WS6 6spd Hooker LT
    However, if it is lean both banks a lot of times it ends up being a dirty MAF. You still running one or are you SD? Also a weak fuel pump will cause both to be lean, as will a vacuum leak.
    Mar 2012
    MICH
    Black N Gold
    Well sounds like theres a few things to check . And yes running a Granitelli MAF . The prev owner sent the PCM to LSX Solutions after all the updrades and I have'nt done anything diff to the engine. Would more money for a Frost tune be of any benefit ? Any idea on an approx cost ? It's prob one of those compare apples to apples thing.
    Thanks
    Indianapolis
    I think Frost mail order tunes are about $150. If you've put about 1400 miles on it and now this suddenly is happening, then it most likely is not a tune related issue. I'd check or have someone check the basics first, like mentioned above.
    Although, if it was borderline lean for a while, it can run fine almost on the verge of setting the code and then it finally sets and turns on the light. You'd have to check the fuel trims, and see if you can see your O2 sensors respond. Also, sometimes coatings on the inside of the headers can foul the O2 sensors and cause fuel trim problems. If it runs great on WOT, then that usually proves out the fuel pump/filter, since the engine would be noticably down on power.
    Coral Springs, Fl
    Look over fuel pressure, and check for vacuum leaks. I would seriously consider a dyno tune though. Mail order is good, but after you start changing internals like the cam you're better off putting it on a dyno.
    Oct 2012
    ardmore oklahoma
    yellow
    2004 pontiac gto
    02's are bad. i have one leanon my 04 gto and it richens up the good cylinder trying to compensate.
  1. running lean
    By occamaroz in forum Computer & Tuning
    Last Post: 12-05-2009, 06:00 PM
  2. Would i be running lean
    By ledesma54 in forum GTO
    Last Post: 03-21-2008, 09:43 AM
  3. Running lean
    By emotionalpiracy in forum External Engine
    Last Post: 11-13-2007, 11:34 PM
  4. Running too lean
    By ddouds2000 in forum General Help
    Last Post: 01-03-2007, 09:27 PM
  5. running lean ??
    By wukash in forum LT1
    Last Post: 08-13-2006, 07:32 AM
