Thread: running lean ??
07-24-2006, 02:13 PM #1Junior Member
- Jun 2006
running lean ??
i have a 1994 trans am about 6 months ago my car was running wierd once it had warmed up. i replaced the 02 sensors and it ran fine till yesterday. once the car warms up (roughly 20 min of driving) it starts missfiring and throws a engine light on... i had the computer scanned at a buddies and its throwing codes 44 and 64 which is the 2 02 sensors and it says they were picking up a lean mixture... now my question is could this all be due to the reason i cut out my catalitic converter and dont have a 3rd 02 sensor ? i didnt think it mattered on a 94
07-24-2006, 05:08 PM #2Junior Member
- Jul 2006
- NC
Have you checked for any exhaust or intake leaks....sounds like you might have some unmetered air getting into the engine or exhaust system
07-24-2006, 07:33 PM #3Junior Member
- Jun 2006
it only seems to happen after 20-30 min of driving ... could this still be an intake or exhaust leak ?
07-26-2006, 09:58 PM #4Fayhee Motorsports
- Nov 2005
- Kingman, AZ
Sebring Silver- 97 Camaro Z28
No it wouldn't matter that the cats gone.. Have you checked the fuel pressure yet? and ideal and at WOT to see if it drops off under a load.. Could be a bad fuel pump or maybe the ground next to the batt.. not letting enough votage to the pump.. All something to check..
Brad
97 Silver Z28
T-56 Conversion, OBDII to OBDI Conversion, Stock bottom end 11.0:1, CC306, Stock ported heads by me, Hooker LT's, Borla Cat-back, MSD DIS 4 w/Delteq, 4:10's, and much more.
Best E.T.: 12.78 @ 111 w/2.03 60"
08-13-2006, 07:32 AM #5Member
- Buffalo
if you have a custom program in the computer, I'd set it back to original then clear the codes, then rediagnose your problem. (Unless you have hypertech programming - I know they dont mess with fuel mixture at normal operation)
Running lean
By MeanMachine1 in forum Internal EngineReplies: 9Last Post: 11-22-2012, 02:33 PM -
running lean
By occamaroz in forum Computer & TuningReplies: 4Last Post: 12-05-2009, 06:00 PM -
Would i be running lean
By ledesma54 in forum GTOReplies: 6Last Post: 03-21-2008, 09:43 AM -
Running lean
By emotionalpiracy in forum External EngineReplies: 5Last Post: 11-13-2007, 11:34 PM -
Running too lean
By ddouds2000 in forum General HelpReplies: 12Last Post: 01-03-2007, 09:27 PM
