Results 1 to 2 of 2
Thread: slave shim from speed inc?
03-17-2008, 05:26 PM #1I need some money
- Feb 2007
- chandler az
hugger orange- 1999 camaro ss
is there anyone out there who has purchased this or knows any info on it? it really sounds like the problem ive have with my clutch and if it works wish i would of knew about it when i got mine installed!
--sorry could get the pic uploaded--
Speed Inc
Slave Shim
If your new clutch is engaging with the pedal to close to the floor, this may be the solution you are looking for. It installs behind your factory slave cylinder in front of the transmission.
**Highly recommended to install this at the same time as your new clutch, while the transmission is out
** Fits 98-02 Camaro/Trans Am, 05-07 Mustang, and most others that have a 2 bolt hydraulic slave cylinder.
itemno description price buy
IZM525 Slave Cylinder Shim $14.99
03-18-2008, 03:22 PM #2I need some money
- Feb 2007
- chandler az
anyone.................bump
Slave Cylinder Shim needed ?
By RRG75 in forum DrivetrainReplies: 1Last Post: 07-29-2012, 03:18 AM -
clutch shim ?
By sgt0704 in forum Manual TransmissionReplies: 2Last Post: 04-14-2012, 01:27 PM -
ls7 clutch shim
By Poppn in forum DrivetrainReplies: 6Last Post: 04-27-2009, 11:30 AM -
Anyone have a Clutch Shim?
By JD_Z28 in forum Western MembersReplies: 10Last Post: 04-06-2007, 06:59 AM -
slave shim?
By 1999z in forum Manual TransmissionReplies: 0Last Post: 09-05-2006, 12:08 AM
