Results 1 to 3 of 3
Thread: clutch shim ?
02-15-2009, 08:55 AM #1Compulsive F bomb dropper
- Apr 2006
- yuma arizona
silver- 1998 Z28
clutch shim ?
i got a spec stage 1. my car is basically all stock. i put it in mid jan. i didn't shim it. we bleed the hell out of it. and everything was fine during the recommended 500 mile break in.
i got on it a few times. mainly hard shifting from a roll, more than hard launches.
and it's getting more difficult to shift into 3rd. at one point during a run, it wouldn't come out of 3rd.
my car has tons of miles, so i expect to need a new tranny in the near future. but i would like to trouble shoot, to make sure it isn't something else first.
i used a new slave from the part store. and i used the TO bearing that came from spec. (mainly cause it looked like the one that was already on the old slave)
the pedal feels a little spongey, so i think it needs bleed again. but how would the clutch feel, if you didn't shim the slave?
would it be more difficult to shift between gears?
would it make a slight grinding sound when shifting?
thanks for your time and your help.
joseph
04-11-2012, 05:45 PM #2Junior Member
- Mar 2012
- Naugatuck ct
Blue- 98 camaro z28 6 speed
yes, u need to shim the back of the slave, the spec clutch should have came with it, if not there on ebay
04-14-2012, 01:27 PM #3
Agreed, you need to install the supplied shim. I would also recommend a new master cylinder from Tick. Definitely recommend. I did the stage 2 spec, and the factory master wasn't enough to fully move the clutch. I would recommend you do this BEFORE you ruin your tranny (like I did.)
ls7 clutch shim
By Poppn in forum DrivetrainReplies: 6Last Post: 04-27-2009, 11:30 AM -
slave shim from speed inc?
By huggerls1 in forum DrivetrainReplies: 1Last Post: 03-18-2008, 03:22 PM -
Anyone have a Clutch Shim?
By JD_Z28 in forum Western MembersReplies: 10Last Post: 04-06-2007, 06:59 AM -
slave shim?
By 1999z in forum Manual TransmissionReplies: 0Last Post: 09-05-2006, 12:08 AM -
Gauging intrest SpecII clutch PP Fly and Shim
By keno2095 in forum Parts For Sale / TradeReplies: 1Last Post: 04-11-2006, 01:32 PM
