Thread: ls7 clutch shim
    nut butter Poppn's Avatar
    Connecticut
    1999 Camaro SS
    ls7 clutch shim
    i'm having one installed and was wondering if any of you have used a shim? do i absolutely need to shim the slave or is it not needed?
    mechanic said there is about a 1/2 inch difference in total height of the clutch/flywheel compared to stock.
    i'm also having a new slave and master put in
    tia
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    The LS7 should be the same height as the stock clutch.
    There is no shim needed. If you put one in, it will make the clutch pedal grab high. It will release right at the top of the travel, which you don't want.
    When you first drive the car, the clutch will grab right at the bottom of the travel. This is normal, since the LS7 uses a self-adjusting pressure plate. As you drive and put miles on it, the pedal will gradually rise to the center point of the travel where it is supposed to be,
    Connecticut
    1999 Camaro SS
    alright sounds good.
    I'm gonna have to ask the mechanic to measure the height again since it should be the same.
    we talked about shimming the slave, but I keep reading that it isn't necessary so I'll probably have him go ahead and put everything together.
    What happens if he measures again and there is still a height difference? i.e. the assembly is shorter/longer going towards the transmission than stock
    I've never even once bothered to look. I've installed many of them and never had any issues except for the occasional need to bleed the clutch. Everyone has been like stated above just put it in and go.
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by Poppn View Post
    The pressure plate is self adjusting, so that may have something to do with the height difference. Remember, its brand new and the pressure plate fingers have never even been compressed, as compared to your old one which is well worn.
    USA
    Velocity Yellow
    2008 Corvette Z06
    Quote Originally Posted by Wesman View Post
    Thank's Wesman, I actually did not know that. I was all ready to get an adj. master since my pedal was grabbing so low.... but the guru of the LS7 has come through for me!!
    Thanks again!
    2018 Tahoe - Silver - OEM
    NJ
    SGM
    1998 Trans Am WS6
    Thanks again!
    No prob
  1. clutch shim ?
    By sgt0704 in forum Manual Transmission
    Last Post: 04-14-2012, 01:27 PM
  2. slave shim from speed inc?
    By huggerls1 in forum Drivetrain
    Last Post: 03-18-2008, 03:22 PM
  3. Anyone have a Clutch Shim?
    By JD_Z28 in forum Western Members
    Last Post: 04-06-2007, 06:59 AM
  4. slave shim?
    By 1999z in forum Manual Transmission
    Last Post: 09-05-2006, 12:08 AM
  5. Gauging intrest SpecII clutch PP Fly and Shim
    By keno2095 in forum Parts For Sale / Trade
    Last Post: 04-11-2006, 01:32 PM
