Thread: Head Gaskets
    Member kev70ss's Avatar
    Yorba Linda
    2000 Camaro ss
    Head Gaskets
    Im going to be swapping some ls6 heads on my car are these good gaskets to use.
    http://www.gmpartsdirect.com/results...row=1&pkgid=66
    I was going to use the set on the bottom of the page, my question is if i use thinner head gaskets would i gain more power cause of higher compression and would i need different pushrods?
    Bragg NC
    Met. Sunset Orange
    01 SS
    I wouldnt be so concerned with finding "thinner" gaskets, Not a good idea, although while you have your valvetrain pulled apart its a good idea to upgrade all components. Including the Pushrods, somewhat of a weak spot in our motors.
    J
    Simpsons Did it!! 98formy's Avatar
    Minnesota
    83 Z28 new project
    98 Formula WS7-sold:(
    I used those same head gaskets, no problem. I agree with sunset, just use the stock thickness and make sure you upgrade your valvetrain. If you plan on running a cam in the future, now is the time to use some good springs with the heads off.
    Yorba Linda
    2000 Camaro ss
    I heads i have came with yellow valve springs, so those should work till .580. I was going to run a mild cam with prob about .568 lift. What pushrods are needed, I was thinking 7.4?
  1. head gaskets for my ls1
    By freaky57fast in forum Internal Engine
    Last Post: 08-07-2013, 07:42 PM
  2. head gaskets
    By 01tao6gto in forum Internal Engine
    Last Post: 07-07-2008, 12:12 AM
  3. Head gaskets???
    By ZCam95 in forum LT1
    Last Post: 05-23-2008, 10:44 PM
  4. Head Gaskets
    By 98formy in forum Internal Engine
    Last Post: 01-26-2008, 06:01 PM
  5. f/s AFR 205cc, head gaskets, and head bolts
    By slimeball6969 in forum Parts For Sale / Trade
    Last Post: 08-12-2005, 09:17 PM
