Thread: Head Gaskets
    Simpsons Did it!! 98formy's Avatar
    Minnesota
    83 Z28 new project
    98 Formula WS7-sold:(
    Head Gaskets
    When you guys do a head swap, are you using oem gaskets or cometic. Do you also need arp head bolts or again are oem ok. I picked up a set of good used patriot perf. stg 2 64cc heads for a steal of a price.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Depends on what comp. ratio you plan on running but i would use oem, although do not reuse your oem bolts, there torque to yield so you are going to have to pick up some new bolts, either arp or oem. Although i would go with the arp.
    J
    Member MikeMoss's Avatar
    Kansas
    Rally Red
    2001 Camaro B4C
    I blew a head gasket and I didnt want it to happen again so i went with the cometic. I ended up using oem replacement bolts because I couldnt get the arp's when I needed them.
    Austin, TX
    2002 Trans am WS6 T-top
    It depends on your buget for the bolts, but with cometic gaskets you have a wider range of thicknesses to dial in your combo for your application. I have never heard of oem bolts failing. I mean, you are shooting for a two stage system or some big time boost. Just make sure the heads are machine right for the the cometics and the block is extremly clean.
  1. head gaskets for my ls1
    By freaky57fast in forum Internal Engine
    Last Post: 08-07-2013, 07:42 PM
  2. head gaskets
    By 01tao6gto in forum Internal Engine
    Last Post: 07-07-2008, 12:12 AM
  3. Head gaskets???
    By ZCam95 in forum LT1
    Last Post: 05-23-2008, 10:44 PM
  4. Head Gaskets
    By kev70ss in forum Internal Engine
    Last Post: 03-11-2008, 11:34 AM
  5. f/s AFR 205cc, head gaskets, and head bolts
    By slimeball6969 in forum Parts For Sale / Trade
    Last Post: 08-12-2005, 09:17 PM
