    Member freaky57fast's Avatar
    Feb 2013
    michigan
    2002 WS6 A4, 2010 ram
    head gaskets for my ls1
    I just dropped off my 799 heads to a shop to do work on and was wondering what I should go to for head gaskets when the time comes to put them on. The guy at the shop said the stocks would work just fine but Idk I'm lost in this department any help for a newb? Thanks all.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Stockers work just fine but the aftermarket will help you spend more of your money. Are you going to use any power adders ?
    what is the shop doing to the heads? Milling them for a flat surface or 0.030" or how much? It does matter!!
    If the later you need to be concern with ptv (piston to valve clearance) Doing a minor mill to level the heads you'll be ok, it's when they start taking more material off that the gasket thickness & push rod length start coming into question.
    Feb 2013
    michigan
    They did a pressure test and then cleaned up no major mill work done just cleaned up the scratches. Was thinking of doing a port and polish job though. No power adders whatsoever I dislike super turbo and juiced engines.
    Coral Springs, Fl
    Sunset Orange Metalic
    You should be fine with the stock gaskets
    Agree but I would still check to make sure the push rods are correct
    Feb 2013
    michigan
    how do I do that? could Texas speed help out when I go to buy the cam in the package with rods and springs?
    Any time heads are milled, cam swap or rockers are swapped out your push rods should always be checked. It saves you from buying another set of rods. TS&P can get you close but they are still guessing unless they are there with your car.
    Comp Cams Push rod checker. Each complete revolution is equal to .050 inch, cost $20
    Part #7702-1 I got mine from WS6store.
    Feb 2013
    michigan
    Aaah I see I believe that is an added option in the can package I was looking at for about 15 extra. I love bundle buys first mods I bought were a bundle.
  1. head gaskets
    By 01tao6gto in forum Internal Engine
    Last Post: 07-07-2008, 12:12 AM
  2. Head gaskets???
    By ZCam95 in forum LT1
    Last Post: 05-23-2008, 10:44 PM
  3. Head Gaskets
    By kev70ss in forum Internal Engine
    Last Post: 03-11-2008, 11:34 AM
  4. Head Gaskets
    By 98formy in forum Internal Engine
    Last Post: 01-26-2008, 06:01 PM
  5. f/s AFR 205cc, head gaskets, and head bolts
    By slimeball6969 in forum Parts For Sale / Trade
    Last Post: 08-12-2005, 09:17 PM
