    houston, tx
    1999 Camaro SS
    Strange sound coming from brakes...
    Car is a 1999 Camaro SS
    Well i just got brand new stock pads all around as well as all the rotors resurfaced 5 months ago. just recently when i step on the brakes it will make a sound, not a squeak but just a sound of friction. nothing bad or high pitched, it just caught my attention b/c it never used to do this. i know the pads are not already worn out b/c they are brand new. the sound is almost just like a psssss sound, like a sound of soft pad sliding against metal. what could this be?
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Probably cheap pads...what kind did you put on?? I usually don't turn rotors....kinda pointless IMO. You can buy brand new ones at autozone fairly cheap...like $40, especially because when you turn them it makes the rotor weaker and they tend to warp easier.
    Junior Member ZedTwoEight's Avatar
    L.A.
    pewter
    1999 Z28
    doesn't sound like anything to worry about. New pads, new rotors=new sounds.
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    I put cheap pads in for my truck once...kinda made the same sound that you have.
    houston, tx
    1999 Camaro SS
    there not cheap pads though
    there OEM gm pads.
    I Fixed Da Rear jimbo98z's Avatar
    Raleigh, NC
    Mystic Teal
    1998 Z28 M6
    could be that they were not broken in properly. some pads need to get a couple cycles of light braking in before you can hit them hard. A friend of mine got the same brake setup I have (Hawk HPS pads on powerslot rotors) and noticed a grinding noise that i don't. Long story short: if you're stopping, the brakes aren't getting really hot, and you aren't tearing anything up, i wouldnt worry about it.
  1. Replies: 45
    Last Post: 07-21-2016, 08:12 AM
  2. Another strange sound ???
    By Ortiz11b in forum General Help
    Last Post: 09-25-2011, 12:54 PM
  3. strange sound ,,, please help
    Last Post: 08-30-2011, 11:59 AM
  4. Strange sound coming from rear end
    By dreed2 in forum General Help
    Last Post: 08-15-2009, 08:54 AM
  5. Easter is coming... strange conspiracies...
    Last Post: 03-30-2007, 12:25 PM
