Results 1 to 20 of 27
Thread: strange sound ,,, please help
07-11-2011, 05:52 PM #1
Ok getting a strange sound from under the car.. It almost sounds like im dragging something... and i think its the rear end bearings... it just started today and i just was pulling out of the driveway and didnt hear it in reverse but as soon as i put in drive and gave it a little gas i heard a grinding noise... let off the gas and it quit... anybody have any ideas on what elsei can check before ripping the rearend apart??? thanks
Car has 180k miles on it.... and a previous owner change out the gears and put in 3.23 gears(so im told)... motor has 60k on it and tranny has less tha 1200 miles on it..
07-11-2011, 05:57 PM #211 years of bangin gears
- Jan 2009
- North Jersey
Have you noticed any leaks from the rear?
07-11-2011, 06:07 PM #3
i havent seen any oil in the driveway.. and these old looking oil around the housing ,,, dosn't look recent... think it could just be low on gear oil????
07-11-2011, 06:11 PM #4
it could be brake pad wear indicators - that usually makes a grinding sound... do you know the age of the brakes/pads?
07-11-2011, 06:17 PM #5
the pads are suppose to be fairly new... but the rotors dose look a little groved... would it do it all the time and not just in drive under acceleration? it didnt do it in reverse or when i got off the gas...... but i will check that asap thanks
07-11-2011, 06:19 PM #6
being low on gear oil wont make that noise unless the rear end is totally shot. put the ass end up in the air, put it in gear and let the rear end roll. get a long screw driver or a mechanic's stethescope if you have one and listen to the pinion and case side bearings to determine the racket location
07-11-2011, 07:53 PM #7
07-11-2011, 08:43 PM #8
i will inspect the brake pads and the rotors. Did you just started to notice the noise or did it started after they changed the pads?
Try this. remove the cap from the master cylinder and listen for pressure release. Put the cap back, drive the car and see if it still happens.
07-11-2011, 08:56 PM #9
No it stared 3 days ago.. as i was driving home kinda heard a pop.. and engine stutered a bit.. then it sounded like my car was dragging something... got out looked and there was nothing under there... so babied it home and made it fine... my 1st impression was maybe a cat going bad... i had planned to change out the spark plugs when i got home...so i did... after letting it sit for 2 days i took it for a test drive and started fine.. backed up fine.. but as soon as i put it in drive and gave it gas.. it sounded like i was dragging something again... so turned around and parked back in the driveway... a hour later i started it up and drove it back and forth with the door open trying to hear the sound and it wouldn't do it.... im puzzled.... is it cats????,,, brakes????,,,or gear bearings????......lol
07-12-2011, 06:18 AM #10
could be ebrake stuck closed... i'd think it's not unheard of.. not sure what the cause/effect of the "pop" noise would've been though...??
07-12-2011, 07:34 AM #1111 years of bangin gears
- Jan 2009
- North Jersey
Is it a dragging sound or a hiss? If it's a hiss, could be the cats.
07-12-2011, 09:24 AM #12
more of a dragging/grinding sound....
07-12-2011, 09:51 AM #1311 years of bangin gears
- Jan 2009
- North Jersey
Did you do what Blue02Z said and jack up the rear and listen for any noise?
07-12-2011, 11:07 AM #14
Not yet,,, im swamped with Summer College classes and will be doing that in the morning.
07-12-2011, 12:31 PM #1511 years of bangin gears
- Jan 2009
- North Jersey
OK.
07-13-2011, 10:15 AM #16
Ok update.... i jacked it up and listened to the rear end... the sound is coming from the outside edges... so im leaning more towards its the ebrake hanging or the axle bearings... but got too dang hot to continue here in Texas(already 100).. so will take diff cover off tonight to check fluid and also take brake rotors off also and check the ebrake shoes... but im thinking it the axle bearings
07-13-2011, 02:32 PM #17
what you can do to help see if it is the axle bearings is drive it and get it to make the noise then going down a straight road and start doing long slow swerves and see if the noise gets louder or quieter under a load. brakes shouldnt change under a load like that.
07-13-2011, 05:08 PM #18
08-07-2011, 07:45 AM #19
Well i have been out of town and wasn't able to work on the car, and after further inspection i see the pinion seal leaking. So what ive been told is "the leak will normally tell you where the bearings have gone bad"... so i was hoping it was just axle bearings but afraid it is the pinion bearings, so ill be dropping the rear end out today for a complete rebuild. Ive never had to take out a rear end before so if anybody has any helpful hints it would be appreciated. Thanks
08-07-2011, 08:06 AM #20
You'd be better off and cheaper getting an entire new 10 bolt assembly. They can be had for around $250. I personally would not soak ANY money into your current 10 bolt.
Another strange sound ???
By Ortiz11b in forum General HelpReplies: 4Last Post: 09-25-2011, 12:54 PM -
Strange sound coming from rear end
By dreed2 in forum General HelpReplies: 3Last Post: 08-15-2009, 08:54 AM -
strange buzzing sound at startup?
By Poppn in forum General HelpReplies: 13Last Post: 05-14-2008, 11:09 AM -
strange metal cling sound and exhaust problem..
By DW2000TA in forum General HelpReplies: 2Last Post: 11-12-2006, 06:19 AM -
Strange sound coming from brakes...
By chris5 in forum General HelpReplies: 5Last Post: 12-07-2005, 10:18 AM
