Thread: Port and Polish
    Jan 2008
    Pampa Tx
    1998 Formula
    Port and Polish
    Can some one give me some direction on porting and polishing my throttle body such as what i need and steps ......i have searched but cant find really any directions
    Member ls1speedster's Avatar
    Bethany, IL
    2002 trans am
    a dremel.
    what i did when i did mine was i took a dremal with some 60 grit sand paper bit.
    spin it at whatever rpm you are comfortable with...
    went around it good toook off some material. I took enough off of what i felt comfortable with...but you have to feel of the thickness in some spost it will start to get thin..
    on the back side(intake side) port that also that you can port more there is some metal behind it...then i went over the whole thing with 80-120 grit not taking material off just smoothing it up..
    just where the blade touches the throttle body do not touch it with the dremel..if you do it will raise your air at idle making rpm come up..leave where the blade touchs alone.
    just knock off the sharp edges and take it down some.
    stock can only be ported to 78 i think?
    i could tell in throttle response when i nail it at 40-110
    if you dont feel comfortable dont do it...
    hope it helps you
    Member Mike's TA's Avatar
    Austin, TX
    99 Trans Am(sold)
    Is that all you have to do. I thought you'd have to get a new blade and what not. I may have to do it this weekend.
    West Virginia
    Y2K WS6
    There is some really good instructions
    http://www.gmhightechperformance.com...ons/index.html
    Happy Reading
    in my Trans Am
    2000 Trans Am WS6
    i thought this mod was pretty much worthless,....unless you change your intake manifold...?
    Arizona
    In theory it should be beneficial. Probably more so if you have a camshaft, headers, etc...
    I ported mine last year and ran the car at the track for a comparison, I gained nothing. I really can't notice anything on the street either, and throttle response is about the same. Although my car is still running the stock puny truck camshaft too. It's such a mild change it's difficult to document any improvements.
    I would assume a back to back comparison on a dyno has been done, with and without,,,,and there might be a measurable gain there,,,,in the neighborhood of a few HP depending alot on the rest of the car though. But you won't see 4-5 HP at the track,,,such as in my case.
    Still worth while though I believe,,,,as you install a cam, heads etc....a larger or ported throttle body will start to shine.
  1. port and polish my MAF?
    By jakez28 in forum External Engine
    Last Post: 04-08-2010, 06:20 PM
  2. Question: port and polish TB and MAF?
    By NavdeepWS6 in forum External Engine
    Last Post: 08-13-2009, 10:31 PM
  3. Question: port and polish?
    By mark21742 in forum Internal Engine
    Last Post: 04-07-2008, 07:23 AM
  4. port and polish
    By SSMOKEshow in forum External Engine
    Last Post: 04-03-2008, 05:16 PM
  5. Port and polish
    By arozar in forum Internal Engine
    Last Post: 06-24-2006, 01:55 PM
