Thread: Port and polish
    Tallahassee
    2001 Pontiac TA WS6
    Talking Port and polish
    This might be a stupid question, but can you use a dremel tool to port and polish heads/TB, etc....?
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    I wouldnt recommend it for heads. I used it on my t/b but you have to be careful not to take out too much. You can mess one up in a hurry. Heads there is no way I would attempt that. No way to tell if they are even. I would leave that to professionals.
    Alien Baby FuriousGeorge's Avatar
    Feb 2006
    Tinker AFB, Oklahoma
    Midnight Blue
    I found that if you use a large sanding cylinder on a drill to port the throttle body, that worked better than anything i tried with the dremel. Only used three cylinders, probably could have gotten away with two though. Good luck.
    Member 89LX's Avatar
    East Coast North Carolina
    Navy
    2000 Z28 M6
    I started off using a dremel tool on my throttle body and was taking for ever. I put a 80 grit sanding cylinder in my small drill press like "FuriousGeorge" and made short work of it. I went back to the dremel for fine tuning and polishing. Did the same on the MAF. I would recommend you take your heads to a machine shop. Good Luck
  1. port and polish my MAF?
    By jakez28 in forum External Engine
    Last Post: 04-08-2010, 06:20 PM
  2. Question: port and polish TB and MAF?
    By NavdeepWS6 in forum External Engine
    Last Post: 08-13-2009, 10:31 PM
  3. port and polish???
    By gcrippin_iii in forum Internal Engine
    Last Post: 07-05-2008, 07:29 AM
  4. Question: port and polish?
    By mark21742 in forum Internal Engine
    Last Post: 04-07-2008, 07:23 AM
  5. port and polish
    By SSMOKEshow in forum External Engine
    Last Post: 04-03-2008, 05:16 PM
