    Member NavdeepWS6's Avatar
    Sacramento
    2002 Trans Am
    port and polish TB and MAF?
    i have a question about getting my TB and MAF port and polished.
    ive done the TB bypass and want to get it ported now and while its out i was going to get the maf done too
    will it run lean or any other complications if i get both of them done without a tune?
    or will the MAF do its job and adjust it.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Do yourself a favor and don't ruin your MAF; leave it alone. If you are looking for HP, look somewhere else.
    Junior Member DesertRat's Avatar
    May 2008
    Brooklyn, NY
    1998 Camaro Z28 conv'
    How about the TB, will porting it create more complication then benefits? or it's consider a safe mod that isn't massing up the way the car runs?
    I'm planning to tune the car via your mail tune service in the near future and would like to get your opinion before I'll send my TB for porting and polishing.
    Thanks.
    Sacramento
    2002 Trans Am
    ok i knew about the MAF might be a problem so im going to just try to pick up a z06 one if i can for cheap but will having the TB port and polished be fine
    Turgid Member Goat-E's Avatar
    Jun 2009
    Hollywood, Florida by way of Da' Burgh
    Impulse Blurr
    2004 GTO
    I did both of mine myself and before the new exhaust I would bog down in the lower RPM's but now with the exhaust it's fine. I've been at this a long time though so if you are inexperienced you might consider an aftermarket or Z06 MAF and getting a pro to do your TB. You also might want to consider an EGR/oil bypass canister.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Quote Originally Posted by NavdeepWS6 View Post
    ...so im going to just try to pick up a z06 one if i can for cheap but ....
    What is the obsession people have with the MAF... BOLT ONS CARS DO NOT NEED A NEW OR MODIFIED MAF. REALLY. ...I'm not yelling at you, just in general. I make this post on this board or some other one like every other day.
    Yes you can port your TB. If you change or alter the MAF, you need to get your car tuned too, though porting them ruins their WOT consistency.
    Jun 2009
    Impulse Blurr
    2004 GTO
    [/b]
    I just smoothed out the ridges and polished my intake pieces. You are correct though, volume isn't doing you any favors in the lower RPM range at WOT. I feather the throttle.
    Sacramento
    2002 Trans Am
    [/b]
    alright thanks for the heads up then i'll just get the TB ported and polished
  1. port and polish my MAF?
    By jakez28 in forum External Engine
    Last Post: 04-08-2010, 06:20 PM
  2. port and polish???
    By gcrippin_iii in forum Internal Engine
    Last Post: 07-05-2008, 07:29 AM
  3. Question: port and polish?
    By mark21742 in forum Internal Engine
    Last Post: 04-07-2008, 07:23 AM
  4. port and polish
    By SSMOKEshow in forum External Engine
    Last Post: 04-03-2008, 05:16 PM
  5. Port and polish
    By arozar in forum Internal Engine
    Last Post: 06-24-2006, 01:55 PM
