Thread: knock sensor
    The Anti-Rice PureSShp00's Avatar
    Longview, tx
    2000 Camaro SS Coupe M6
    knock sensor
    so my check engine light came on and i took it yo auto zone and they hooked up the scanner to see what was wrong and they said its the knock sensor... i bought the part... just cant find where it goes... even from the diagram they gave me... any suggestions?
    Member NSSTG8TR98's Avatar
    Mesa, AZ
    Black Vert
    1998 Camaro SS M6 #1160
    under the intake manifold. Crankshaft position sensor is next to starter.
    Longview, tx
    sounds like a pain in the ass??
    Senior Member 01ws6er's Avatar
    The 717
    2001 Trash Can
    Quote Originally Posted by PureSShp00 View Post
    Actually it's not bad at all. It will be a lot easier if you have a garage and all of the right parts/ tools at your disposal. You only need an intake manfold gasket set, possibly a TB gasket (if you take it off), New o-rings for injectors (if you decide to take them out)....it's not necessary, but it's a lot easier to remove the fuel rails/ injectors as one, 2 knock sensors, and maybe an oil sending unit (it's at the back of the block, behind the manifold and VERY easy to break off). Seriously, just buy a Haynes or Chiltons manual and it'll help out a lot. I did mine in about 1 1/2 hours. It's actually not that bad, the worst part is taking off the manifold bolts. PM me if you want more info.
    Senior Member
    Jacksonville, FL
    There are two knock sensors, both under the intake - the code will tell you which one is acting up - if diagnostics confirms it's a knock sensor I'd replace both if pulling the intake.
    Mesa, AZ
    Black Vert
    http://www.ls1howto.com/index.php?article=5 pretty good write up showing how to get to those Knock sensors.
    pulling the intake on these cars is cakewalk compared to most. No gaskets needed. Just need a 10mm and an 8mm wrench. Make sure you don't break the oil pressure sending unit with the brake booster hose when you're pulling the intake out....very easy to do. The sending unit is on the drivers side just behind the intake. There are 2 ways to do the fuel line, you can either get a quick disconnect tool and take the line off or after the bolts are out holding the fuel rail down you can just pop all 8 injectors out and swing the fuel rails and injectors back out of the way. I've done it both ways and both are pretty easy to do.
    A handy trick is once the back 3-4 bolts on the intake are loose you'll notice that the cowl prevents them from being pulled all the way out. Pull up on the bolt and put a piece of masking tape around it to keep it from falling back down and then it won't try to hang on everything as you're pulling the intake forward.
    Once you get the intake off stuff rags or paper towels into the intake ports on the heads, you don't want a bolt or something to roll down into the ports.
    As long as you have it tore down that far go ahead and replace both sensors. Wash the engine bay with a garden hose? That will kill knock sensors if water gets to them by getting under the intake.
    The 717
    2001 Trash Can
    Quote Originally Posted by NSSTG8TR98 View Post
    Nice pics and info. For me personally, it was easier to remove the fuel rail and injectors before I took off the manifold. Space is a huge issue in there, and it was just easier for me. Good luck.
  1. knock sensor code with new knock sensors?
    By zaaronz in forum General Help
    Last Post: 02-27-2011, 06:26 AM
  2. Knock Sensor ?
    By Jheath5193 in forum General Help
    Last Post: 01-20-2011, 02:31 PM
  3. Which knock sensor do I need?
    By SMWS6TA in forum General Help
    Last Post: 12-27-2010, 10:09 PM
  4. will bad knock sensor knock down hp
    Last Post: 10-14-2010, 04:49 PM
  5. Knock Sensor/Oil Pressure Sensor Issue
    By Slow '99 in forum External Engine
    Last Post: 04-04-2007, 08:28 AM
