    Which knock sensor do I need?
    Which knock sensor do I need, with or without the locating tab?
    What brand would you recommend for a Knock Sensors?
    Advance Auto has
    ACDelco - 58
    Delphi - $60
    O'Reillys has
    BWD - $50
    Master Pro - $60
    Autozone has
    Duralast - $47
    Austin, TX
    2002 Trans am WS6 T-top
    I take it its for the 98 T/A. Go with Delco/Delphi. I had some issues with BWD parts, its a no wonder that the cheaper the part or lack of quality has the longest warranty. Just my .02 cents. I would replace both knocks and the harness. The wires are usally hard and brittle at the base (black round circle top).
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Definitely AC Delco or Delphi (probably the same thing)
    phoenix
    04 2500 4x4 crew cab
    x2 for the harness.
    Auto Painter RyanJM's Avatar
    Houston, TX
    We just.got a set of delco 's for the 02 LS1 doing into.my friends 240sx. Got the on eBay brand new $50 for the set. When it comes to replacing factory parts like that I use delco on my TA and trailblazer and motorcraft on my 93 5.0. Always fit and works the way it should.
    1998 Trans Am 85k miles.
    02 Trailblazer -Sold
    09 Ram 1500 CC - Sold
    09 Cobalt SS/TC - Sold
    Cutlass, I'm having problems finding the harness do you have the part number?
    GMPartsDirect told me its not in service anymore.
    Madison, WI
    2001 Silverado Z71
    No I don't but apparently there are 2 different style knock sensors on Gen III LS engines. If you swap in the 99 to 2002 knock sensors, then you can use the 99 to 2002 harness which I found with a quick google search
    harness # 12601822
    Senior Member
    texas
    2000 formula
    the new style KS is on the right
  1. knock sensor code with new knock sensors?
    By zaaronz in forum General Help
    Last Post: 02-27-2011, 06:26 AM
  2. Knock Sensor ?
    By Jheath5193 in forum General Help
    Last Post: 01-20-2011, 02:31 PM
  3. will bad knock sensor knock down hp
    Last Post: 10-14-2010, 04:49 PM
  4. knock sensor
    By PureSShp00 in forum External Engine
    Last Post: 01-29-2008, 04:22 PM
  5. Knock Sensor/Oil Pressure Sensor Issue
    By Slow '99 in forum External Engine
    Last Post: 04-04-2007, 08:28 AM
