Thread: Noisy engine compartment
01-16-2008, 09:31 AM #1Junior Member
- Sep 2005
- Northern California
Arctic White- 98 Z-28
I have a 98 Z28 M6 that is stock except for an intake, exhaust and short shifter. However, lately the engine is squeeking more. Nothing crazy but just louder and making more chatter than it has been. I checked and made sure everything is tight-it is, but it still is making noise. I would just rather hear the exhaust than the motor. Anyone else have this problem or should I just let it go?
01-17-2008, 04:04 PM #2
does it make a sound like a bearing going out CAREFULLY take a screwdriver to the idler pulley put your ear to the other end does the sound stay the same or amplifie through the screwdriver? Several pulleys in there start there! How many miles are on the car??? Little more info might help but hope that starts you out...
02-02-2008, 12:39 PM #3Junior Member
- Nov 2005
- coral springs,florida
blue- 2000 firehawk
engine belt whine squeak noise diagnosis
with youre hood open and engine off,of course, remove youre drive belt and start the car with the belt off and listen for the noise,if it is gone then turn it back off and before you decide which pulley is causing it spin them by hand until you find which one feels rough and replace it; if the removed main belt does not make the noise go away then also remove the ac belt and start it up and see if the noise is then gone and check those 2 remaining pulleys and spin the ac compressor also to check it; if you still hear the noise with both belts off do not waste a dime replacing pulley and look elsewhere for the problem; good luck!
02-02-2008, 05:59 PM #4
very intelligent - why didn't I think of that suggestion??? Running the motor with no belts for a SHORT period of time will cause no harm no foul. My idler pulley went out on me (between the P/S pump and alternator). But I still have a whine coming from in there - week before the alternator went belly up on me. I suspect the A/C pulleys but right now Im putting a new transmission in an old ford pickup truck I bought for next to nothing to sell for a little spare change.
by the way I like this icon... See ya and good luck!
02-02-2008, 06:05 PM #5
02-05-2008, 03:58 PM #6Junior Member
- Sep 2005
Yeah with 108,000 on the clock I figure its time to change em also...Just need a day off to take care of it. Thanks for the input.
AIR system in engine compartment
By sasquatch094 in forum Firebird / WS6Replies: 1Last Post: 04-16-2010, 12:19 PM -
Engine compartment cooling
By bahdeets in forum General HelpReplies: 27Last Post: 02-24-2010, 11:08 AM -
98 T/A engine compartment
By Archaelas in forum Firebird / WS6Replies: 14Last Post: 04-06-2009, 07:44 PM -
my way to clean up the engine compartment
By 35thAnniZ28 in forum Camaro / SSReplies: 19Last Post: 09-16-2007, 01:10 PM -
Best Way To Clean Engine Compartment
By SS_Crazy in forum Camaro / SSReplies: 11Last Post: 05-19-2007, 12:12 PM
