Results 1 to 20 of 28
Thread: Engine compartment cooling
02-20-2010, 04:00 PM #1Junior Member
- Feb 2010
- detroit
silver- 2007 SS monte carlo
Is anyone familiar with engine compartment cooling. I have a Monte Carlo and am concerned with excess heat in the compartment with the LS7 I put in it. Can compartments be vented and how. Through the fender wells - are there aftermarket products to assist me here?
02-20-2010, 04:09 PM #211 years of bangin gears
- Jan 2009
- North Jersey
Are we talkin about the Monte in your sig?
02-20-2010, 04:12 PM #311 years of bangin gears
- Jan 2009
- North Jersey
Some will "flute" their hood. "Flute" as in vents like on the old Vegas. Lets the heat out and keeps the engine happy. Others go the cowl hood route. You could go with either of these or go with a dual electric fan setup. Other folks will add to this.
02-20-2010, 04:27 PM #4Junior Member
- Feb 2010
- detroit
I like the vented hood idea like the Vegas you mentioned - that idea I will research, thanks - by the way how is the rain kept out? At this point I would rather not spend the money on another hood that is cowled. But I still wonder if there is a fenderwell solution
02-20-2010, 04:28 PM #5Junior Member
- Feb 2010
- detroit
I forgot to say - I have dual fans - by the way what is a sig?
02-20-2010, 04:35 PM #6Senior Member
- Apr 2008
- Madison, WI
sig = signature
02-20-2010, 04:36 PM #7Junior Member
- Feb 2010
- detroit
thanks
02-20-2010, 05:50 PM #8
02-20-2010, 08:16 PM #9Junior Member
- Feb 2010
- detroit
Cammed Goat: I found some hood vents on ebay for a 68/69 SS Camaro. They are an exact replica in detail and are polished billet aluminum and they are perfect. Look good and will do exactly what I want them to do and that is vent hot air up and out of the engine compartment. Now all I have to do is cut the slots and fit them - and buy them too of course. Great idea thanks for you help. Even found the answer to my rain question. I guess hood vents are panned to keep the rain out of the engine compartment.
02-20-2010, 11:02 PM #10
02-21-2010, 04:53 AM #11Junior Member
- Feb 2010
- detroit
Smittro: On your Z-34 are the vents incorporated into the hood or are they separate pieces that bolt on?
02-21-2010, 06:54 AM #12
You can remove the cowl seal and radiator support seal (if so equipped) to allow additional airflow through the engine compartment. Just be sure that removing the radiator support seal does not affect the volume of air that is forced through the radiator.
02-21-2010, 07:04 AM #13
02-21-2010, 10:45 AM #14
02-22-2010, 05:29 AM #15Junior Member
- Feb 2010
- detroit
I have about 400 pix now showing all my progress; the hoods vents will eventually get taken but it probably will be the last thing I do. This project is already into it's 15th month and soon to be completed - working out the bugs. Trying to prevent fuel cavatation at the pump now - researching coolers by Dana currently. And trying to lower my oil temp - but I don't have room for another cooler anywhere in the engine compartment. Another dilemma to overcome. If it isn't one thing its another.
02-22-2010, 05:53 PM #16Junior Member
- Feb 2010
- detroit
Cammed Goat: Just ordered those vents today. I am getting them in a black satin/machine anodized finish to match my black flush hood latches. Want to keep the same color scheme. Black on Silver. When those are installed I will definitely have pix to post. I don't know how but the individual who is doing my pictorial, I will ask him to do it for me. And from what Smittro mentioned I should be able to vent alot of my engine compartment heat which will be very good.
02-22-2010, 06:28 PM #1711 years of bangin gears
- Jan 2009
- North Jersey
Good man. I luv Montes. But then again I am a slave to the General.
02-22-2010, 06:53 PM #18
02-23-2010, 04:50 AM #19Junior Member
- Feb 2010
- detroit
What's a General?
02-23-2010, 05:54 AM #20
98 T/A engine compartment
By Archaelas in forum Firebird / WS6Replies: 14Last Post: 04-06-2009, 07:44 PM -
Noisy engine compartment
By lmyers1 in forum General HelpReplies: 5Last Post: 02-05-2008, 03:58 PM -
my way to clean up the engine compartment
By 35thAnniZ28 in forum Camaro / SSReplies: 19Last Post: 09-16-2007, 01:10 PM -
Best Way To Clean Engine Compartment
By SS_Crazy in forum Camaro / SSReplies: 11Last Post: 05-19-2007, 12:12 PM -
Best way to clean engine/compartment
By SloLt1Camaro in forum LT1Replies: 3Last Post: 09-05-2006, 09:15 PM
My z34 has funtioning hood vents from the factory. You'd be amazed when both fans are running how much hot air gets evacuated. They have a channeled pan to divert rain water too.
