Thread: 2002 Z28 Drive Shaft Question
01-12-2008, 03:52 PM #1Junior Member
- Aug 2007
- Centennial, CO
Black- 2002 Z28
Just measured out my drive shaft as I was thinking about getting an aluminum or carbon fiber replacement. I was seriously contemplating a 3.5 inch diameter with Spicer 1350 joints and slip yoke.
OEM Length from U-joint center-to-center was 41 3/4 inches.
OEM drive shaft circumference was about 8 inches = about 2.546 inches in diameter.
1) Is it true that the LS1 package already includes an aluminum shaft?
2) Has anyone out there installed a 3.5 diameter shaft? And if so, did you have clearance issues?
Many thanks in advance...
01-12-2008, 04:08 PM #2Internet Tough Guy
- Nov 2007
- Oregon
Sinister, SixGun- 2001 SS, 2002 L36 M5
ive got a 3.5" shaft with 1350's in my M5. its a little larger than stock, but still clears fine.
i think the total price of my shaft, u-joints, and both jokes was like $320 shipped. lemme know and ill get you the guys number.
2001 M6 SS - few mods...
01-12-2008, 05:31 PM #3
Not all LS1's came with aluminum- only if you had 3.23 or 3.42 rear end- optional on the A4 or the standard.
The 'fuel economy' rear axle came with steel and 2.73's-
01-14-2008, 08:17 AM #4
i didnt know that the 2.73s had steel shafts. i might need to get an aluminum one now.
01-15-2008, 03:03 PM #5Junior Member
- Aug 2007
- Centennial, CO
Black- 2002 Z28
3.5 Aluminum Drive Shaft
To date, the only location that is close to under four bills is Carolina Driveshaft.
So, what's the number? PM me if you can...would be much appreciated.
Drive Shaft
By transamgreen in forum DrivetrainReplies: 8Last Post: 09-25-2016, 05:45 AM -
drive shaft fit
By mikey gavin in forum DrivetrainReplies: 0Last Post: 05-10-2011, 11:40 AM -
Drive shaft
By andyramsaran in forum GTOReplies: 4Last Post: 04-02-2010, 08:01 PM -
Drive Shaft not going in!!!!!!
By nmmccasland in forum Manual TransmissionReplies: 3Last Post: 06-11-2008, 11:24 AM -
Drive Shaft
By stevenm357 in forum DrivetrainReplies: 6Last Post: 03-04-2008, 08:42 AM
