Thread: Drive Shaft not going in!!!!!!
05-27-2008, 02:39 PM #1Junior Member
- Apr 2008
- Tampa, FL
Red- 1999 Trans Am
Two questions:
1) I just had my tranny rebuild, and I installed it with a new clutch, new throwout bearing, pilot bearing, a slave cylinder. But now the drive shaft wont go in. The tranny shop said it could be the yoke or the bushing. Any suggestions?
2)Does anyone have a step by step on how to bleed the Hydraulics for the clutch. Everything is already connected, I have the fluid, but I got stumped when I tryed to use the a mitty vac to bleed it.
Thanks
05-27-2008, 02:51 PM #2
05-27-2008, 03:15 PM #3Junior Member
- Apr 2008
- Tampa, FL
Red- 1999 Trans Am
ill try that
06-11-2008, 11:24 AM #4
theres a bleeder valve on the side of the tranny for the slave.
the master cylinder has to be bench bled
Drive Shaft
By transamgreen in forum DrivetrainReplies: 8Last Post: 09-25-2016, 05:45 AM -
Help: drive shaft
By sjohnson904 in forum DrivetrainReplies: 0Last Post: 05-20-2013, 09:19 AM -
drive shaft fit
By mikey gavin in forum DrivetrainReplies: 0Last Post: 05-10-2011, 11:40 AM -
Drive shaft
By andyramsaran in forum GTOReplies: 4Last Post: 04-02-2010, 08:01 PM -
Drive Shaft
By stevenm357 in forum DrivetrainReplies: 6Last Post: 03-04-2008, 08:42 AM
