Thread: Drive shaft
04-01-2010, 06:35 AM #1Junior Member
- Mar 2010
- Oak Lawn/ Chicagoland
Yellow- 2004 GTO
Drive shaft
Any boby out have problems with GTO driveshaft 2 pice center bearing mount It's 70 deg in Chicago and took the car out 1 st time since falland hear banging noise from center of car lift it up and found support bearing rip nobody sell the support bearing only, Dealer or you can buy a one pice driveshaft for about $900 or junkyard for about $200 from Cleveland pick a part
04-01-2010, 09:02 AM #2Senior Member
- Mar 2008
- OHIO"S only 9 second GTO
Phantom Black Metalic- 2005 GTO
I have a few complete stockers laying around,and I can get you a new 1 peice aluminum shipped direct to you for $725.
04-02-2010, 07:31 AM #3Junior Member
- Mar 2010
Yellow- 2004 GTO
how much you want for the stock one?
04-02-2010, 01:04 PM #411 years of bangin gears
- Jan 2009
- North Jersey
If/when mine goes, I think I will go with a 1-piece unit.
04-02-2010, 09:01 PM #5Senior Member
- Mar 2008
Drive Shaft
By transamgreen in forum DrivetrainReplies: 8Last Post: 09-25-2016, 06:45 AM -
Help: drive shaft
By sjohnson904 in forum DrivetrainReplies: 0Last Post: 05-20-2013, 10:19 AM -
drive shaft fit
By mikey gavin in forum DrivetrainReplies: 0Last Post: 05-10-2011, 12:40 PM -
Drive Shaft not going in!!!!!!
By nmmccasland in forum Manual TransmissionReplies: 3Last Post: 06-11-2008, 12:24 PM -
Drive Shaft
By stevenm357 in forum DrivetrainReplies: 6Last Post: 03-04-2008, 09:42 AM
