Thread: temp switch location?
01-02-2008, 12:33 PM #1Junior Member
- Nov 2005
- GEORGIA
black- 2000 Z-28
where is the temp switch located on a ls1? not to sound stupid but i cant find it ? my problem is the cooling fans are not operating and that is one of my so called first things to replace i think? if i am correct? have any of you had this issue before they do work on a/c cycle . if i am a dumbass say so but please let me know which areas to look into before replaceing fan motors . thanks for all your help . phillip
01-02-2008, 12:39 PM #2Senior Member
- Jun 2007
- Harrisburg, PA
Blackety Black- 35th Anniversary SS
are you looking for the thermostat or the temp. sensor?
did you check all your fuses in dash and under the hood?
01-02-2008, 12:44 PM #3Junior Member
- Nov 2005
- GEORGIA
black- 2000 Z-28
looking for the temp sensor . i already replaced thermostat.. thanks
01-02-2008, 12:49 PM #4Senior Member
- Jun 2007
- Harrisburg, PA
the engine coolant temp sensor is located on the drivers side head and will have two wires on a 2000 car
01-02-2008, 03:37 PM #5Senior Member
- Jun 2007
- corona ca
white, white and pewter- Rip99SSA4,74Z28M4,02SSM6
its located right above the 2nd bolt for the driver side exhasut manifold, also before replacing it take a paper clip and jump the wires if the fans turn on then you can just replace that switch, if not you need to start with either fues and or relays until you then decide that BOTH motors went out which is really unlikely, try flipping your a/c on, the fans should then turn on as well
01-03-2008, 09:27 PM #6Single Malt
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
[quote=phillip wigington;1223232] please let me know which areas to look into before replaceing fan motors quote]
One fan should come on at a certain engine temperature or when you turn on your AC.
The second fan comes on when the engine reaches a higher temp & will cycle on & off as the engine heats & cools.
Thinking of putting Oil Temp & Trans Temp gauges
By ernie22golf in forum General HelpReplies: 1Last Post: 12-27-2014, 09:39 AM -
Question: trans temp sensor location?
By 383ls6 in forum Automatic TransmissionReplies: 6Last Post: 01-05-2012, 11:27 AM -
wire from stop lamp switch to turn/hazard switch?
By swisscheese in forum Stereo and ElectronicsReplies: 1Last Post: 08-11-2008, 11:22 PM -
fuel pump cut off switch location??
By truakita in forum General HelpReplies: 4Last Post: 07-24-2007, 02:50 PM -
Battery Cut-off switch location
By Transam388 in forum General HelpReplies: 0Last Post: 10-16-2006, 07:37 AM
