07-23-2007, 08:00 AM #1Junior Member
- Jul 2007
- Ms.
silver- 2000 camaro ss
fuel pump cut off switch location??
Can anyone tell me the location on 2000 SS? I looked on Advance Auto Parts web site and they sell one for my car. I know my problem is that switch or a bad oil pressure switch or computer. Wires are good.
Thanks,
Truakita
07-23-2007, 06:11 PM #2
never seen, or heard of, one on our cars. also, the car will run with a bad oil pressure switch.
07-24-2007, 04:37 AM #3Junior Member
- Jul 2007
- Ms.
Thanks for reply. Advance does sell one! Haynes book says if engine fails to start in 2 seconds the fuel pump is shut off until engine developes oil pressure, then it comes back on. Got any idea what does the job? Maybe the ECM?
I am new to the forum, what is the best way to view my posts? I have had to do a lot of scrolling to find them!
Thanks Again
07-24-2007, 02:38 PM #4
what's weird is the car's will run even if the oil pressure sending unit isn't functioning. some years had a two prong oil pressure sending unit. later years have one prong.
up near the top left of the forum is User CP. click it. this takes you to your profile. then on the left side select Edit Options. under Messaging & Notification is Default Thread Subscription Mode. select instant email notification. this will send you an email when someone replies to a thread you have started, or replied to.
other option is to use the search. under search select advanced. then put your board name in the name box and click search. this will bring up all posts that you have replied in or started as well.
07-24-2007, 02:50 PM #5Junior Member
- Jul 2007
- Ms.
I sure thank you and my scrolling fingers are very thankful also!
Write-Up: Fuel Pump Kill Switch
By nichoLaS1 in forum General HelpReplies: 19Last Post: 03-13-2016, 09:30 AM -
Help: Would it be bad to put my fuel pump on a on/off switch?
By jrbonds in forum General HelpReplies: 7Last Post: 04-06-2015, 03:34 PM -
temp switch location?
By phillip wigington in forum General HelpReplies: 5Last Post: 01-03-2008, 09:27 PM -
Battery Cut-off switch location
By Transam388 in forum General HelpReplies: 0Last Post: 10-16-2006, 07:37 AM
