Results 1 to 17 of 17
    2002 Trans Am WS6
    what's the deal with Bilstein/Eibach combo?
    So, i keep hearing that bilstein just aren't good anymore... or am i confused.
    I've been debating suspension/springs upgrade on my 02 T/A . I'm debating Koni SA (still looking into springs, maybe keep stock?) vs the Bilstein shocks/Eibach Springs. I'm looking to lower the car somewhere betweem 3/4" to at most 1 1/2".
    any thoughts out there?
    at this point, i'm not worried about money, as i'm going to either wait for bonus check or save from my paycheck until it's time...
    NetrixTardis
    Aug 2000
    Indy
    Hotchkis has a kit. Biltsien ( I read ) had a QA issue basically. They are no longer a good quality replacement shock, something about a different mfg technique or diif inners. I'm goin Koni's but front first, then rear. Too much $ to drop at once.
    doylestown, Pa
    SILVER
    2004 CTS-V
    Bilstein is reproducing the shock. They will be available late March.
    Senior Member
    rochester,ny
    pewter
    2001 z28 lingenfelter 383
    click on the strano link under sponsors...then give him a call...koni's/strano springs
    That is great news. Where did you read/hear that?
    link?
    Aug 2000
    Indy
    Don't hold your breath
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    Another Vote for Strano
    I'll be ordering from him in a couple months.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    doylestown, Pa
    SILVER
    2004 CTS-V
    link?
    I spoke to Bilstein.
    Aug 2000
    Indy
    NICE ^ , checks in the mail
    Brookville, PA
    2001 Z28
    This is the same Bilstein that people speak to that has said (via individuals who just work there and don't necessarily know anything): HD's are fine for lowering spring, even though their own catalog tells you this is not the case. That the "new" HD that was better than the old one. And at other times to me that the "new" HD was simply a tube supercession with no valving change.
    And I have not seen one Bilstein since this PAST March. Yes, they might be back in 2008, but even if they are it remains to be seen if they really build the "old" version again. And if they do, that's still not up to the task of damping lowering springs correctly. Though at least then we'll be able to do Revalves again.
    Sam Strano
    SCCA National Champion (x6)
    SCCA ProSolo Class Champion (x5)
    2009 SCCA ProSolo Overall Champion
    Owner--Strano Performance Parts
    814-849-3450
    doylestown, Pa
    SILVER
    2004 CTS-V
    Quote Originally Posted by Sam Strano View Post
    Well, thats funny, cause I called your Company and one of your staff recommended that I wait for the Bilstein's.
    2002 Trans Am WS6
    ok. So Bilstein shocks are out...
    i've already decided to go with Koni SA shocks, now i'm trying to decided if i should pair those with lowering springs. As i see it, i'm going to set the shocks to 3/4" lower.. but i would rather not go lower, is there aftermarket springs that are better than stock, but won't lower the car?
    Quote Originally Posted by NetrixTardis View Post
    Not aftermarket but you can get stiffer spring rate by finding 1LE take off springs from a legit 1LE optioned car.
    Senior Member
    rochester,ny
    pewter
    stop being a cheapskate and spend the extra 200 on koni's ( revalved bilsteins are about 600 last i checked)
    Brookville, PA
    2001 Z28
    And?
    I have no idea what you conversation entailed. It's clear you would like to go that way, which is fine and if you are willing to wait for them, and hopefully they do what they are supposed to that's your call, and probably why you got that recommendation.
    I'm telling you what I know, and that I personally wouldn't put a lot of stock into seeing them on any given date since I've had 3 "ETA's" come and go since last March.
    Brookville, PA
    2001 Z28
    You can, but it's not really worth is. Frankly, I like the non-1LE rear springs better in most situations. My lowering springs don't run as much rate as 1LE rears do (but we run more in front).
    I'd save your money. My car is a non-1LE, I ordered it that way. I ordered it specifically as a autox car, and having driven 1LE's felt there was not a downside. And in actuality many more events have been won by "normal" 4th gen's than by 1LE 4th gens.
    doylestown, Pa
    SILVER
    2004 CTS-V
    Quote Originally Posted by tonyjnjz View Post
    Cheapskate! I don't think so! I am putting on the factory equipment from my 97 SS.
  1. Question: Bilstein shocks+eibach pro springs=tire rub!
    By arock24 in forum Suspension and Handling
    Last Post: 09-21-2011, 01:28 PM
  2. Question: Anyone used the Bilstein/Eibach kits?
    By thomasterrible in forum Firebird / WS6
    Last Post: 08-16-2010, 02:39 PM
  3. Bilstein, Eibach, need some help
    By weberje in forum Suspension and Handling
    Last Post: 12-05-2009, 12:09 AM
  4. your opinion on slp eibach/bilstein
    By ZEFF in forum Suspension and Handling
    Last Post: 10-04-2008, 03:48 PM
  5. life expectancy of Eibach/bilstein setup
    By kickarss in forum Suspension and Handling
    Last Post: 12-07-2006, 08:48 AM
