Results 1 to 1 of 1
08-16-2010, 02:39 PM #1
Anyone used the Bilstein/Eibach kits?
I am interested in results others have experienced with the widely available Bilstein sport shock/Eibach spring kit. I know I like the shocks from previous use. I am really interested in any ground clearance issues that may occur. In particular I am planning on upgrading the rear to a 12 bolt for added strength so I will also have a slightly bigger differential casing.
I have used similar shocks with good results in the past but unsure if the lowering is worth the gains in CG for handling and if there are any problems with scraping parts such as the rear end. Right now the car has a slight rake on a flat surface which I assume is normal. Also it doesnt take much to scrape the under chin plastic spoiler on the front of the car. It makes sense to do the rear end and shocks at the same time and if the springs wont cause trouble those as well.
Thanks in advance.
Bilstein, Eibach, need some help
By weberje in forum Suspension and HandlingReplies: 17Last Post: 12-05-2009, 12:09 AM -
SLP Bilstein / Eibach spring shock package
By blackbird2001 in forum Suspension and HandlingReplies: 22Last Post: 05-31-2009, 07:51 PM -
Bilstein Shock & Pro Kits
By karpetcm in forum Suspension and HandlingReplies: 5Last Post: 05-24-2009, 07:42 AM -
your opinion on slp eibach/bilstein
By ZEFF in forum Suspension and HandlingReplies: 4Last Post: 10-04-2008, 03:48 PM -
what's the deal with Bilstein/Eibach combo?
By NetrixTardis in forum Suspension and HandlingReplies: 16Last Post: 01-02-2008, 03:23 PM
