Results 1 to 10 of 10
09-18-2011, 11:42 AM #1
Bilstein shocks+eibach pro springs=tire rub!
My 02 z28 rubs (minimal) in the rear after replacing the shocks/springs. The drop was only suppose to be 1-1.5" but it was obviously too much for my wheels/tires. I'm fairly ignorant when it comes to suspension, but will a spring spacer solve this problem?
35th Anniversary z28 A4
Pacesetter headers-Flowmaster 40-3.23-CME-Bilstein shocks/Eibach pro springs-SLP Lid-K&N-ram air-Centerline 17"
13.28 @ 107mph
09-18-2011, 01:06 PM #2
Eibachs are notorious for sacking but, yours are new so that shouldn't be the issue.
If you don't have stock wheels and tires on her, your running in dark water.
They should work with the stock stuff.
Measure your fender height from the ground for each side.
They should be within a 1/4 inch of each otherBe who you are and say what you feel 'cause people who mind don't matter, and people who matter don't mind.'
-Nowhereman
09-18-2011, 02:52 PM #3
It's my wheel offset, the tires are only 275's, I had 295's on my 97 without any issues. Fender height is identical on both sides. I was wondering if there was a solution without changing my wheels. I've seen these "spring spacers", but I did not know the reputation of them. I figured a 2.5" spacer would be more than enough for my clearance.
09-19-2011, 01:52 PM #4
After a little reading/research, I've decided to try and get my fenders rolled by a body shop, I'll post results thursday
09-19-2011, 03:13 PM #5
Hopefully they have experience with doing this. If they don't take their time, use the proper amount of heat, and finesse it just right, you're going to notice on the outside of your quarter-panel.
09-19-2011, 03:23 PM #6
I'm not too worried about paint, it's been needing a paint job. The shop seemed to have a legitmate portfolio. I'll post new pics of the finished work and my chewed up tires
09-19-2011, 03:56 PM #7
Good luck, that's the sexy way of getting clearance if possible.
09-19-2011, 07:15 PM #8Senior Member
- May 2009
- college station, tx
sold: 1999 firebird- 1998 Trans Am
subbing for rolled fender pics
09-19-2011, 08:08 PM #9
tire rub sux. I have the same setup but with no issues. I do have to watch the speed bumps. Did you buy them together as a kit? some places tune the setup to work for your car
09-21-2011, 01:28 PM #10
Imperfections are not from the body shop. This is what your car looks like when you don't have a garage. Probably about 6 separate door dings all on passenger side. Waiting til I have proper storage before I do any body work..
My lesson learned:
Overall results are a much better ride. No more chewed up tires! Definately recommend this being done for anybody who is having clearance issues.Last edited by arock24; 09-21-2011 at 01:32 PM.
Question: Eibach Sportline Springs and Bilstein HD shocks?
By mrbvlo in forum Suspension and HandlingReplies: 5Last Post: 06-26-2012, 05:28 PM -
bilstein shocks or eibachs springs ?? looking not too much $
By greatwhiteZ28 in forum Suspension and HandlingReplies: 1Last Post: 09-09-2007, 07:39 PM -
are the eibach springs and shocks really worth it from Belle tire?
By greatwhiteZ28 in forum Suspension and HandlingReplies: 3Last Post: 03-02-2007, 11:04 PM -
Bilstein BTS Sport Shocks and Springs?
By 95TAGary in forum Suspension and HandlingReplies: 4Last Post: 08-07-2006, 07:35 PM -
Bilstein Springs and Shocks
By arozar in forum Suspension and HandlingReplies: 0Last Post: 05-17-2006, 01:33 AM
