    Junior Member mrbvlo's Avatar
    Feb 2007
    Sneads Ferry, NC
    Pewter Metallic
    2000 WS6 Formula
    Question: Eibach Sportline Springs and Bilstein HD shocks?
    Got a stock 2000 WS6 Formula. I've already purchased the springs and am wanting to get the Bilstein HD shocks. My question is about the spring perches on the front de carbons. Will the spring perches come off the stock de carbons and can I use them on the Bilsteins? And if so, would the stock perches be compatible with the Eibach Sportline Springs (kit #4.7083)? I noticed the Bilsteins are listed as being 46mm in diameter (part # 24-024068), not sure of the de carbons. Perhaps someone has done this particular combination before and would know if I need any other hardware. Or perhaps another shock would be more compatible with the Sportlines? Thanks. (I don't race or autocross; I'm just doing a WW that may perhaps be a showcar one day.)
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    I have slp bilstein shocks with vogtland springs. I just replaced all the shock hardware with new upper and lower spring perches, as well a new isolator and cover. I bought monroe and moog parts, if you need it I can find the part numbers.
    However, you can reuse the old parts if wanted.
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    Feb 2007
    Sneads Ferry, NC
    Pewter Metallic
    2000 WS6 Formula
    Thanks 98. I was hoping the perches would come off and could be reused with the bilsteins. I'm going to see if I can get the old hardware off and then as long as it's serviceable, I'll use it. If not, I'll be asking for those part numbers. I know I could just call Bilstein or Eibach, but I'm not sure I'll get someone on the phone who really knows what they're talking about. I appreciate hearing it first hand from someone who "actually" did it! I plan on taking alot of photos to document the process.
    Orlando, FL
    Mean Black
    I'm just waiting in my OEM coil springs. I have bilsteins shocks for the front standing by. I ordered everything brand new from rockauto.com in case I need them. The spring perch comes right off once the coil is removed. If you need a new one they are pretty cheap.
    Orlando, FL
    Mean Black
    I just finished installing all the bilstein shocks. I was able to reuse the perch, eibach spring mount and boot. I put a new isolator and a new bump stop. So far so good. they are alittle more stiffer than the monroes but they feel better. The car doesn't bottom out no more. The bump stops were destroyed. I'm testing the eibach springs and then decide if I keep them or not.
    Orlando, FL
    Mean Black
    I think this was part of my problem. The thing is that i push the shaft of the monroe shocks in and it seems to come out fine. It almost like the shock is not bad.
  1. Bilstein Shocks with stock springs - install question
    By ceta4zng in forum Suspension and Handling
    Last Post: 04-03-2012, 09:29 PM
  2. Question: Bilstein shocks+eibach pro springs=tire rub!
    By arock24 in forum Suspension and Handling
    Last Post: 09-21-2011, 01:28 PM
  3. FS Eibach SPortline Springs/KYB Shocks ALmostNEW!!
    By 5abivt in forum Parts For Sale / Trade
    Last Post: 03-03-2010, 02:01 PM
  4. Question: Best Shocks for Sportline Eibach Springs?
    By rob_taylor916 in forum Suspension and Handling
    Last Post: 08-30-2008, 12:25 AM
  5. Eibach Sportline Springs
    By Christibelle in forum Parts For Sale / Trade
    Last Post: 04-04-2007, 12:33 PM
