Results 1 to 2 of 2
09-09-2007, 06:03 PM #1
bilstein shocks or eibachs springs ?? looking not too much $
just seeing what would be prefered for mostly street/strip and for first order? but basically for the 1/4
09-09-2007, 07:39 PM #2Member
- May 2007
- Columbia, MO
Medium Blue Metallic- 1999 Pontiac Trans Am
If you are looking for a 1/4 mile strip setup neither will benefit you much at all. I would recommend a torque arm if you want strip handling performance. As for (street suspension) which to do first, you should probably wait until you can do them together as the install on the fronts is a major PITA. But keep in mind if lowering with the eibachs you will benefit greatly from some rear suspension components such as adj panhard, adj torque arm, and lower control arm relocation brackets. In other words, if you are tight on money and will do the install yourself-get the bilsteins.
Bilstein Shocks with stock springs - install question
By ceta4zng in forum Suspension and HandlingReplies: 5Last Post: 04-03-2012, 09:29 PM -
Question: Where To Purchase Stanos Springs & Bilstein Shocks
By Redrokit8 in forum Firebird / WS6Replies: 6Last Post: 12-21-2011, 02:41 PM -
Question: Bilstein shocks+eibach pro springs=tire rub!
By arock24 in forum Suspension and HandlingReplies: 9Last Post: 09-21-2011, 01:28 PM -
Bilstein BTS Sport Shocks and Springs?
By 95TAGary in forum Suspension and HandlingReplies: 4Last Post: 08-07-2006, 07:35 PM -
Bilstein Springs and Shocks
By arozar in forum Suspension and HandlingReplies: 0Last Post: 05-17-2006, 01:33 AM
