Results 1 to 2 of 2
    Member Sunset T/A's Avatar
    Spring, TX
    Sunset Orange
    2002 TransAm
    Crane Cams Power Tuner Question?
    I bought a Crame Cams Handheld Tuner a couple of years ago for my T/A. I used it a couple of times, so it is VIN locked to my car. I returned my car to stock tune, then had a dyno tune done with LS1 Edit. Can I use this tuner only to read and delete codes, or will it mess something up? Does anyone know the answer for sure? Thanks guys.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    yes, you can use it to read/clear DTCs without messing up your tune. you have to go through the initial reading of your PCM and select no through the whole process. then go back and read/clear DTCs. you only have to do the inital reading of the PCM once. after that, you can go directly to read/clear DTCs.
  1. Crane cams Tuner
    By [email protected] in forum Computer & Tuning
    Last Post: 03-18-2009, 03:23 PM
  2. For Sale: crane cams/ vinci power programmer
    By 4U2ENVY in forum Parts For Sale / Trade
    Last Post: 06-22-2008, 01:52 PM
  3. crane cams?
    By emotionalpiracy in forum Internal Engine
    Last Post: 05-21-2008, 06:10 AM
  4. F/S Crane Cams Power tuner
    By sneaky7980 in forum Parts For Sale / Trade
    Last Post: 03-09-2008, 08:11 PM
